Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Thanks for the great detailed thread.
Wondering best vendor to source POR-20 aluminum satin paint . . . .
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 04-23-2008, 04:52 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Originally Posted by Porsche-O-Phile View Post
How would you get current leakage with the switch being off? Sounds like a bad switch maybe? Interesting, but I'd suspect any issue like that would be indicative of other problems.
I contacted one LED manufacturer and they stated some older cars will leak current which will be picked up by the LEDs and they recommended a Load Equalizer to absorb the leak but it would act like a standard DOT light in efficiency. They could not give an opinion if the 3 or 5 Watt LEDs will make a difference. I just did not want to drop another $60+ to see if it is the case.
Please keep us posted on the 5 Watt LEDs when running during the day with lights off. I hope you are succesfull
Funny thing is that I have installed a LED third Brake Light and it does not glow. Apparently the DOT combo absorbs the leak and does not effect the Third Light LED.
BTW, I pasted aluminum foil where the reflective material has flaked off in the brake light and it worked great.
'85 Carrera Targa
PCA/POC
Old 04-23-2008, 06:28 PM
DRACO A5OG's Avatar
Hey POP,
Any updates on the LED, specifically the low glow of the LEDs when the lights are off with car on?
'85 Carrera Targa
PCA/POC
Old 05-19-2008, 02:57 PM
moneymanager's Avatar
Just noticed, shouldn't the amber turn signal bulb above be an 1156, not two filament 1157?
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 06-01-2008, 02:23 PM
Carrera Cab Connoisseur
nyne11's Avatar
subd
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 06-01-2008, 04:41 PM
Inspired by Jeff"s thread here, I got two of Super Brights 5 watt LED bulbs for my 74's taillights. I'm happy to report that, in addition to their many other advantages, they are (I'd estimate) about 20% brighter than the traditional two filament bulbs and, just as important, the directional coverage seems excellent. This is indeed an improvement in visibility. On the Super Bright site, the bulbs are the 1157 RLX-5's. The R means red, which is essential if you want to get the expected brightness.
jhtaylor
santa barbara
Old 06-01-2008, 08:03 PM
DRACO A5OG's Avatar
That's Great!
Now did you confirm if the rear lights remained off when you turned the lights off and car on?
My LEDs glowed when she was on and lights off.
Please advise,
'85 Carrera Targa
PCA/POC
Old 06-01-2008, 08:07 PM
MIK911's Avatar
Awesome write up POP!! Be sure to post some pics on car.
Anyone replace 3rd brake light (high mounted inside rear window, on '86) with LED? What LED cluster would work best here?
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 06-01-2008, 08:24 PM
I have no lights on with switch off.
There is a Pelican thread on doing an LED third brake light. BUt everyone (except me I guess) has missed the easy and sensible solution...the Hella aftermarket LED third brake unit available from daniel stern lighting. $50, very bright, looks like it belongs on the car, in contrast to some of the kluged together set ups on the thread. Take a look.
jhtaylor
santa barbara
Old 06-01-2008, 08:33 PM
Monkey Butt Forespin
84_Carrera's Avatar
$.02 from a guy who did the superbrightleds.com bulbs for his Taurus SHO years ago, including the resitors to compensate so you don't get the lamp out lights on the newer cars...
The lights (when I got them, about 2 years ago) looked great on the bench. However, in the light / twilight out on the road, I had many people tell me they couldn't see my brake lights. I tried the white bulbs behind the red, then the red bulbs behind the red... no real change.
Thought I'd share. Incidentally, yours do look great, hope they work out for you, but watch the rear-view, just in case...
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 06-01-2008, 09:07 PM
Thanks, I'll keep my eyes open. My impression is that the LED units are improving all the time. In particular, many of the newer units are visible in a 200° arc, not typical just a couple of years ago when there were many complaints that if you got off axis the lights were invisible. Unless these new bulbs deteriorate rapidly or something else untoward happens, they are looking very good. They are brighter than stock and they show very good visibility well to the side of the car (ie off axis.)
jhtaylor
santa barbara
Old 06-01-2008, 09:24 PM
DRACO A5OG's Avatar
[QUOTE=moneymanager;3977726]I have no lights on with switch off.
QUOTE]
Great, looks like I am pulling the trigger on those 3-5 watt babys
'85 Carrera Targa
PCA/POC
Old 06-01-2008, 10:07 PM
johncmng's Avatar
Subbing
Old 06-02-2008, 11:10 AM
MBruns for President
JeremyD's Avatar
Fred - not the case these days - My LED's are brighter than stock bulbs -
Old 06-02-2008, 11:56 AM
Subscribed! Great thread. Will tackle this in the future!
Mike
Old 06-02-2008, 12:28 PM
DRACO A5OG's Avatar
Well Gentlemen,
It is an Afirmative!
The RED 5 Watt Luxeon LED Brake Lights (1157-RLX5) worked.
Much brighter than OEM or the other LEDs and the angle of view is perfect.
Apparently the 5 Watt LED draw a bit more current which absorbs any bleeding of OEM current. When the ignition is turned to the on position, no glow to report.
Thanks again POP and MoneyManager for confirming that lights don't bleed.
Again, Wow So Bright! It kind of burned my eyes.
'85 Carrera Targa
PCA/POC
Old 06-09-2008, 09:08 PM
Glad they worked out Draco...your experience is exactly like mine. These LEDs, plus my socket repairs and some other refinements have given me the best rear lighting I've had in years!
jhtaylor
santa barbara
Old 06-10-2008, 07:37 AM
DRACO A5OG's Avatar
Here are some pics from my cell:
Brakes OFF
Brakes ON
Unlike the standard LEDs, it completely fills the brake light housing with light. ( see post 34, sorry JeremyD )
BTW, the Luxeons are brighter than the third LED light as well.
'85 Carrera Targa
PCA/POC
Old 06-10-2008, 04:25 PM
JeremyD's Avatar
Brakes OFF
Brakes ON
No problem - mine was in direct florida sunlight - they look very similiar to yours under cover - filling out the entire brake light.
Old 06-10-2008, 06:08 PM
DRACO A5OG's Avatar
Strange, I wonder why your first pic has that distinct LED outline??? Are you using the Luxeon 5 Watt as well?
'85 Carrera Targa
PCA/POC
Old 06-10-2008, 07:07 PM
