Difference in SWB and later year Steering Column?
Is there any? My steering shaft is very loose in the column and I'm not sure if the 'fix' sleeve is usable. It is listed for 74-89 so it seems there is a difference. Could I use a later column say from an SC to go with my upgraded SC front end?
Robert
Currently Porsche less (but the wife has 2)
Old 04-27-2008, 06:04 PM
Grady Clay's Avatar
Robert,
There is a HUGE difference in steering columns between SWB (’68 and earlier) and LWB (’69 and later).
That said, I think some of the ‘fixes’ for the loose steering wheel syndrome are the same for both SWB and LWB. There is a common bushing in the steering column. The ‘fix’ is a non-standard part that better locates the steering shaft.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-27-2008, 06:56 PM
Thanks Grady, guess I'll try the fix first and see if it actually 'fixes' the problem or not.
Robert
Old 04-27-2008, 07:09 PM
Grady,
What is that fix--I have a 67'?
Thanks!
A.B.
Old 04-27-2008, 08:06 PM
http://www.pelicanparts.com/techarticles/911_Steering-bushing/911_steering_bushing.htm
This one
Robert
Old 04-27-2008, 08:47 PM
Thanks!
A.B.
Old 04-27-2008, 08:48 PM
HarryD's Avatar
Robert,
That fix only applies to '74 and later steering columns. The 928 part will simply not fit.
For earlier cars, you can find the answer here: HELP! Steering wheel bushing quickfix???
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-27-2008, 09:59 PM
Thanks Harry, I remember that thread now, but I couldn't find it.
Robert
Old 04-28-2008, 07:06 AM
Fast Corners's Avatar
Grady is correct there is a big difference between steering columns. Basically it falls within 3 type ranges: Pre '68, '68-'73 and 74 and beyond. The pre '74 cars have the same basic architechture. There is a sealed bearing at the bottom of the housing tube and an open bearing at the top. The inner race of this open bearing is held in place by a spring nut and washer on the steering shaft.
I rebuilt my '73 steering shaft. You need to be careful not to loose the small ball bearings as they will fall out and you will need them to get rid of the slop. The sealed bearing is expensive from Porsche so I took measurements of the original bearing and ordered one from a bearing company on the web. It cost me around $2 a bearing. The spring and races for the open bearing are quite expensive. If you are missing any of those parts I would check with a dismanteler before ordering a new one.
For the most part the earlier cars develop slop in the steering shaft due to missing parts or failure of the open bearing. The later cars develop slop from deterioation of the plastic inner race as shown in the above referenced link.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 04-28-2008, 03:16 PM
techweenie's Avatar
I wanted to revive this thread because there is an overlooked solution in all the technical threads I've seen regarding stabilizing the steering wheel in a '68-73 car.
These cars use a spring and small stamped metal washer to "load" the bearing and stabilize the top of the steering shaft. The spring and washer are held in place by the steering wheel hub. The spring compresses as you bolt down the hub.
Many of us have had cars treated carelessly by P.O.s and their 'mechanics.' About half my cars have started out with a lost spring and washer. Finding and installing a set is the only fix I know of. I'll try to get a picture to illustrate what I'm talking about.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 01-02-2009, 04:51 PM
HarryD's Avatar
You are referring to the items in the link I provided above. The spring and bushing look like this:
And when installed, like this:
Harry
2020 MB E350 4Matic
Old 01-02-2009, 06:25 PM
techweenie's Avatar
Exactly. Those pieces are missing in a fair number of cars. I believe they use a 914 part number.
1969 coupe hot rod
Old 01-02-2009, 06:57 PM
