3.2 engine stall while acc and cruise
My 87 carrera stall and miss while in the track yesterday during DE 1 time it miss about half sec , and came back , one time stall after turn the ignition key it came back again, before that I change the fuel pump, filter, dme relay car modifly to steve wong custom chip autoritory MAF ,SSI M&K muffler 2in 2out other than that it remain stock in engine, any one can help me to solve this issue. thanks
Steve |
I was getting a random engine stop and in turned out to be a broken solder in the DME unit, not the relay, the unit itself. Do a search for DME and solder and you can probably find it. I followed the suggestions and redid the solder joints. Keep in mind they are VERY hard to see, in particular if you have "over 40 eyes" like I do. It took bright sunlight to find them.
Good Luck
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
MBruns for President
DME relay will do that - Cracks in the DME unit itself will do that - Faulty sparkplug wires will do that - coil will do that - even fuel injectors will do that - I usually start off with a baseline and start working up the expense ladder from there - so first of all check all your connections, grounds - then pull your plugs and make sure they are ok as well as your rotor - The do the DEM relay.
After that you start getting into some spendy stuff and service intervals.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
