abides.
Question about B&B heater tubes and engine tin
I'm trying to put B&B headers with heat on my 3.2, and there is a flap of engine tin in the way of the left heater outlet.
Here's a picture showing the flap and the approximate place where the tube needs to be. Do I need to cut a hole here, or am I doing something wrong? B&B's instructions made no mention of this, and I couldn't find it discussed here. ![]() Thanks,
Graham 1984 Carrera Targa |
sudo apt-get purge 930
If your original heater tube did not hit the tin and the B&B does then I would say the B&B is not right. How are you going to attach the flexible tube? Will it require a longer flexible tube if you move the B&B pipe toward the engine?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey Last edited by equality72521; 05-14-2008 at 10:49 AM.. |
abides.
Hmm... good point. I take it then that the connections should be in the same locations?
I'll have to compare the B&B to the stock HE and see what's different. (Not sure why I didn't do that last night... )
Schleprock
Graham,
My B&B headers & a friend's both did the same thing on our 3.2 Carrera engines. You can either notch the shield or drill out the spot welds and take it off. When I took the shield off, I covered the sensor wires in Parker silicone fabric heat shielding wrap. It's the orange stuff at the top right of the page http://www.mcmaster.com/nav/enter.asp?pagenum=791 What you'll also find is that the stock heater hoses are too long since the B&B heater box pipes are longer than the stock heat exchanger tubes. So you'll have to cut the hose a bit.
Kevin L '86 Carrera "Larry" |
I bent that tin upward when installing my headers. As I recall, helping a friend install the B&B headers, had to do the same thing.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
1984-911 M491
Same here, I notched the tin and bent it upwards.. no biggie.
1984-911 TLC......SOLD |
abit off center
+1
BTW KTL, what are you a sales rep for McMaster??
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Schleprock
Just telling people where to get good stuff. Why shop anywhere else? It's the Super WalMart of industrial supply!
Anytime I need something, I always search for it there first. I could buy a freakin' toilet there if I had to. You shop there too. Don't try to hide your addiction. I can see it.Where's my calipers? I need them to whoop you old farts at Grattan!!!
abides.
Awesome... Kevin to the rescue again!
abides.
Ok, I got the headers on (I notched the tin and bent a section upwards), and that's all good. But now I have another question if anyone's listening still.
When I put the engine back in the car, the rubber oil line that runs from the engine oil cooler to the oil tank sits on top of the right header. Does anyone have any tips for fixing that? Sorry for not having pictures... I know that would make this all a lot easier.
abit off center
You need a steel line like this to clear the headers.
Have fun trying to get just that line from the fine folks (cough cough) at B&B........
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Diss Member
GAAAAKKK!
Now that I have the backdate oil lines I thought I had all the pieces needed to put my B&Bs in. Smogged the car yesterday and today I was thinking of putting them in before it gets hot and then someone had to post a picture like this... Hell with it, I'm going out for breakfast.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
abides.
Just out of curiosity, shouldn't that line have some more flex built in? Unless you have solid engine mounts, it seems like you'll be stressing your oil cooler and tank every time your engine moves.
I guess I'm off to get some hoses made tomorrow morning.
abides.
I just called them. They'll sell it to me for a mere $195.
abit off center
If I was to do it again I would not use their oil tube, as you can see its still close to the headers and even with the rubber connectors it does flex but not as much as I would like it too. If you could get or make a metal 90 degree pointing forward out of the tank you could cut down the rubber S hose and make it work.
abides.
I haven't been able to find an elbow with a tight enough radius to clear the header. I'm almost desperate enough to use some copper plumbing elbows and clamp them together with some hose.
Also Craig, did you use the backdated oil line from the engine to the thermostat? Mine seems the be about 2.5" longer than it should be.
abit off center
I did use the backdated line, cant you just put a little more loop in it?
abides.
I can, but the rubber section is nearly kinked. I've been looking for some barb fittings so I can shorten it up, but nothing I've found locally is big enough.
Time for McMaster Carr, I suppose.
abit off center
Here is my line. does it look something like this? Also note I have to dent in the right side heater tube to clear that same line from the engine.
