cubby911T's Avatar
Question on Compression testing
Hi guys. I conducted a compression test on my 2.7 engine last night, but ran out of time before completing #6 cylinder (and what a PITA that #6 is by the way). If I go back to complete that last cylinder, can I leave all the other spark plugs in place while I test #6? Or do they all need to come out again? I wasn't sure if it mattered.
Also....after reconnecting everything last night and restarting the car, it seemed to be stumbling a lot and I could smell gas. Does this sound like I just didn't get a good connection on one of the plug wires?
thanks!
Matt M. -- Go Irish! 1990 964 C2 Targa
"Cheap tools and no experience has taken its toll" - J.W.
Ghosts of the Past: '77 911S Targa 3.2 Conversion, '89 Carrera Coupe, '99 Boxster, '70 911T Coupe ,'80 911SC Targa, '77.5 924
Old 06-18-2008, 06:11 AM
Friend of Warren
Yes you can just do the one cylinder without removing the other spark plugs, just make sure you take measures to insure the engine doesn't start!
I would recheck to make sure you re-installed the plug wires in the correct order and that you got good connections on all of them.
Kurt V
Old 06-18-2008, 06:37 AM
cubby911T's Avatar
Yep, I'll make sure to unplug the CD and also the fuel pump relay....
thanks Kurt!!
Old 06-18-2008, 06:49 AM
