3.2 Banging after oil change
Has anyone experienced a banging noise that seems to come from the timing chain housing???
For the second time, just after an oil change, I have a rhytmic bang from what I believe is the timing chains. The sound goes away and does not come back after about 30-60 minutes of engine idling. After that I can start the car on any given day and the noise does not return. It only seems to be there after I drain the oil and then idle it to allow the fresh oil to circulate. I have a '84 3.2 Carrera and am considering the possibility of having streached timing chains or a bad hydraulic tensioner. Anyone have any suggestions or comments?? |
I have an '84 that did that a few times, not necessarily after an oil change. I did not know what the sound was, but it happened the last time last winter after I drove to a Pelican gathering in Colorado and Grady Clay heard the sound and said it was the chain tensioner. The sound went away on the way home as I believe Grady put the fear on it and it has yet to return.
1984 3.2 Cab (now toy) 1975 911S (old toy) Mercedes E350 W4 (snow car) 2007 911 Turbo (water and air pumper) 2012 Panamera 4S (for the wife, I swear) |
Sounds reasonable. Is there a real potential for the tensioner to fail and cause terrible things that I don't even want to think about?
I've never heard of a failed tensioner that resulted in a banging noise, just the dragging/rrattling chain sound. Grady, are you there? Tell me more.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
UFLYICU
Yes.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
what if they didn't put enough oil, maybe 1 or 2 quarts less?
You let it idle for 60 minutes????
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
I suspect that is 30-60 SECONDS.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Sure hope so......................
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I let the engine idle (and the engine oil was verified to be properly serviced by checking the dip stick) for about 5 minutes at a time. After about the fifth time the knocking or banging noise goes away.
I would like to hear more about the possibility of a tensioner failure or perhaps a bad tensioner seal. Has anyone actually had a 3.2 Carrera tensioner not hold hydraulic pressure and allow the timing chain to "slap" around in the housing? The noise seems to be closer to the crank pulley versus being on either end of the heads, near the cams. I used my automotive stethoscope to try to pinpoint the location of the rhytmic banging. I am really concerned about the tensioner failing or the chain letting go. Thanks for any comments. By the way, the engine has 85,000 miles on it and I just brought it home after a flawless trip from Minnesota through the western part of the U.S., putting 8,500 miles on it. It's still running great and the noise has not returned, it only seems to occur after the oil has been drained and reserviced. |
banging noise
Well I would change them both out ,..or consider the stationary type that does not require the oil pressure,..seems like it sticks and man that can be disastrous..if it fails at the wrong time...FM
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Thanks for the sound bite Frank.
I would say that is close to how it sounds. The quality is difficult but the rythm seems to be the same and the intensity seems to be right... I'm anxious to find out what the cause of your sound was?????? Was it the tensioners? If so, what did you do?? |
Eap
I sent ot over to my mechanic so he could hear it...He told me since they did a leakdown test just 2 weeks ago, it might be my sparkplug connectors leaking or the plugs themselves...I have jacobs wires and they look replaced within the past 2 years...other things he said it could be were a lose valve or rocker....He said he was ok for me to drive it over to the shop, I dont have the room or time to do the work myself at the moment, so i wont know untill they get in there
Thanks again Frank,
Please let me know what they find. Is your noise continuous? Mine has gone away for now but I would sleep a lot better if I knew what the problem is. I'm planning on a 1,500 mile trip over the 4th weekend. My wires are one year old and are Clewett's. I would not rule out a grounding wire as when I was feeling around the engine compartment, with the engine running, I was feeling a light spark from the wires (they were wet because my oil funnel dumped a half quart of oil and I had to wash it off). As for a rocker or valve being the culprit, I'm pretty confident that the valve train is tight. I adjusted valves last year. While I was listening to them with the stethoscope, everything was ticking along nicely. Thanks again, I hope your mech can find your problem and perhaps we have a common "banging". But, that would be too easy wouldn't it..... |
Irrationally exuberant
Resurrecting post from June 2008:
What did the banging turn out to be? -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
