CIS install without drop?
Is it possible to install a complete CIS set up with out dropping the engine or will it require at least a partial drop.
What is all in cluded in a partial drop. 1. Losen coupler and remove shaft. 2. Loosen motor mounts. Is that enough to get it in? Will I have to remove oil lines or loosen the transmission mounts? Thanks!
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
Less brakes, more gas!
Having just put my CIS on my engine on the stand last week I can fully say I could not have done it with the engine in the car... It was such a pain to get all the intake pipes on and then get all the washers & nuts on after that. I was happy I had 360 deg. of access to everything. Sorry, I know it was not what you wanted to hear...
Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Yeah, you'll have to do at least a partial drop. Here's what I do.
1. Jack up the car. 2. Put jack stands under the torsion bars. 3. Raise jack to meet the engine, just behind the oil sump screen. 4. Undo the shift coupler and motor mount bolts. (I don't remove the shaft.) 5. Lower jack to desired height. I've been able to get the fan pulley down probably 10 inches before I start to feel uncomfortable about it.
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
azporsche911.com
It is possible, i have taken out and re-installed CIS on my 79 SC. Its a BIG PAIN IN THE A$$. It can be done but just to save you grief and frustration, partial drop it...
-Jeff
Jeff Hoffman (Son) Tom Hoffman (Father) 79 911sc ROW guards red coupe father son project. |
I'm not so sure a drop is necessary. I recently removed the entire CIS without a drop with these instructions found on this forum. I can't see why the reverse would not be the same.
1. Remove the air boot 2. Remove cruise control cable bracket from throttle body, disconnect cable 3. Remove heater blower motor 4. disconnect fuel supply and return lines 5. disconnect 14 pin connector for CIS electrics 6. disconnect and label the WUR, and AAV 7. Remove the 12 13MM intake runner bolts, the last bolt on six is accessible easier after removing the #4 intake runner from the system. You can then take a 3/8 extension and a 13MM swivel form the front of the car and get it of easily 8. Disconnect the oil breather tube at the oil tank 9. Disconnect the PCV line at the oil tank 10. Lift the CIS system up a few inches, then from underneath the airbox, remove the clamp for the oil breather hose and carefully pry the old hose of the cover. 11. Lift CIS up and pull forward until you reach the top of the fan shroud, then angle back and clear the shroud. 12. Consume adult beverage and congratulate yourself. Takes me about 60 to 90 mins when I still had CIS, takes about 20 now with EFI
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) |
As anyone who was working on these cars back in their heyday can attest (exploding air boxes), it is not only quite possible, with a little practice it's not even that bad. What really helps is having a 3/8" swivel joint as opposed to a U-joint for your ratchet - and an assortment of extentions.
Sure it's easier with the motor on a stand. But it's def not faster. Good luck! |
Dog-faced pony soldier
Yes, you can replace the CIS without lowering the engine. I just got done doing it. Yes, it's a bit of a pain, but it can be done.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Irrationally exuberant
But dropping the motors on these cars is so easy. Why "build a ship in a bottle" if you don't have to?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks, for the info. I tried last night but could not get to fit. Like trying to push a square peg through a round hole.
I might remove the boot to see if that will help. Otherwise I will just do the partial drop as it seems like can acomplish that with having to disconnect everything.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo Last edited by jcc911; 06-26-2008 at 05:14 AM.. |
Somatic Negative Optimist
Even if you are very skilled in mechanical skills, it's frustrating to do; hard on your back and knuckles.
You run the risk of creating vac leaks that are harder to trace later. Things are very congested and a partial drop will help. Check the pressure switch, breather cap and thermostat 0-ring while you're at it. Take your time and be patient; swivel sockets with long extension are a must.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Thanks Gunter.
When I had the engine out, I replaced the breather gasket and used an rubber o-ring for the oil light switch on top. Should I have used copper? A copper washer that size was not readily available in my area. Where is the pressure switch and thermostat o-ring? Isn't the thermostat located in the wheel well?
Several ways to do it........
There are several ways to achieve your goal as you can attest to the different suggestions you have received. You could either do it with a partial drop, complete engine drop, or in-situ for removing/installing a complete CIS unit. Each individual method mentioned offer different degree of convenience and efficiency to complete the job. You make the final decision to which procedure you'll be more comfortable performing. Then ask yourself later after completing the project this question: If I would do this again, what would I do to make it easier and more convenient? You'll probably do something the same or different from others. This was my choice: Picture of an SC 3.0 liter engine running on an engine test stand: ![]() I've removed and replaced a complete CIS system with the motor installed in the car and decided never will I do it again. This procedure is not for everyone but for those few individual who want to have an engine completely tested and running before mounting it in the car. Tony |
i replace blown airboxes on 78/79 with the engine in the car all the time. the key is to account for every nut and washer, look down every intake port for objects and turn the engine over a couple of times to check for washers that may slip past an open valve. not a big deal. the inside nut on #6 is the hardest part. 80-83 with the extra lambda crap, i yank it.
I have done it twice.
The first time I had the engine out, the second time I removed the CIS with the engine in but I had to do a partial drop to get it back in. But the second time I really had a big advantage in having done it before.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
If not, it doesn't have to be copper. An Alu crush washer will do nicely. There are 2 thermostats: One is on top of engine and uses an 0-ring, the other is for the external oil cooler thermostat in the rear wheel well which doesn't require any seals. Leaks on top of the engine are a lot of times from: Breather cap, Breather hose on the cap. (Put a clamp on it) Oil Pressure Switch. (Not just the seal, the switch itself can leak) Thermostat 0-ring (Pull the thermostat out to replace the 0-ring) Go here: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGoil_pg3.htm#item11 and look at the photo. Ignore some of the speed-wizards who can do everything in record time; use common sense and make it as easy as possible meaining: Everything is tight and crowded in the engine compartment, so, give yourself as much room as possible. Things to watch for to avoid vac leaks are the gaskets from intake runner to head. The complete CIS is like an octopus and wants to fight you all the way. What I do: I leave the rubber boots loose and moveable on the runners (I use a little Vaseline on the inside of the boots so they can move) Clamps just snug but positioned so that I can reach the screws for tightening later. Using NEW gaskets, I tighten the runners down on the heads first, then tighten the clamps on the boots. This way I know that the runners are sitting square on the heads. Inspect/replace any hoses that look worn and tighten clamps as needed.
I really don't understand why everyone gets so uptight about this job. It really does look much worse than it is. The one thing you can do to make the job much more comfortable is to get the car up 3' or so just so you don't have to spend the entire time on your knees. Yes, at one point I was quite practiced at this job, but I distinctly remember the first time: it was one of those very rare working-on-car-moments where I ended up thinking - "huh, now that really wasn't so bad". And, while I'm not really big, at 6'0 and 190lbs I don't consider myself really small either. |
It's all relative!
What's easy for some, is not easy for others. Not everyone has the same skills or mechanical aptitude and some people don't seem to realize that.
Just don't violate the ninth major rule of CIS:
If you take the CIS off the engine, do not reinstall it.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
Huh..........??
Just another one of these guys trying to burn down his 911 with carbs
