Wires for instruments. I'm an idiot. PLEASE help!
I REALLY need someones help right now.
I need to start my engine after my renovation, this weekend. Everything is perfect, except my small and large combination instrument. I'm not sure how to connect the wires, because I forgot to mark them when I took them out (big idiot... I know). I'm using three diagrams to be sure to do it right, but i'm still not sure... Can you see theese pictures and tell me if i'm doing it right or wrong? ![]() 911T - 1971 ![]() ![]() ![]() ![]() ![]() Thanks guys!
Irish Green Porsche 911T 1971 Denmark (Scandinavia)... Last edited by watson; 06-26-2008 at 02:49 PM.. |
What car? Year?
Pics don't look like the green 71 t. |
It WAS a green '71.
Now it's light ivory '71. ![]()
Irish Green Porsche 911T 1971 Denmark (Scandinavia)... |
Tree-Hugging Member
From a Green(!) '71:
Small instrument- Solid Green -> Fuel Green/Grey -> Oil Large instrument- Green/Red -> Oil Pressure Green/Black -> Oil Temp Jim
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
Thanks Jim, but I can see that from the diagram. I need to know wich connection points i have to use behind the instruments.
Tree-Hugging Member
OK - pulled my gauges out and....
For your large instrument, it compares with mine except for the top (12 o'clock) connections I have a black with white stripe and a brown with grey dot. Below that I have a single black with green stripe. For the small instrument, starting at 12 o'clock I have a black with blue stripe with a double ground directly below it. To the right of that is the double red/black like yours. Next clockwise I have a solid green, again like yours. Next clockwise is the large fitting and I have a double male spade with a black wire plus the red/black jumpered to it. Immediately to its left I have an empty male spade connector where you show your black wire. Again clockwise the red/black followed by the green/grey like yours. Sorry for the text description - tried to get photos but couldn't get the camera to make a decent closeup. Hopefully it helps. Jim
You made an error with the small combi instrument:
- the black wire should not be used a ground (only the brown) - you used the instrument lighting bulb where the warning light for the fuel level should go. This light is connected to a red/black and the black wire
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Does the gauge fry if the wires are wrong, I might have a similar concern on one of my gauges from a 77 911. I haven't put power to it yet. I did make a diagram but one still seems iffy!
I will correct it tomorrow ![]()
Thread Tools | |
Rate This Thread | |
