Replacing Clutch
Hi All,
Among other things, I am replacing my clutch. I had my flywheel resurfaced and got a Sachs light weight power clutch, new throwout bearing, and a new main flywheel seal. Anyway, a question: Getting the old seal out was a bear. I finally did get it out - without marring the metal around it. I then put some oil on the new seal and pressed it in. Now, I used a blunt instrument to press it into place. I got it flush, but then working around the seal, I was able to press it in about 1/16th of an inch more. Is this ok, or does it absolutely HAVE to be flush??? Mike |
That is fine. Flush is good, slight off from that does not kill you.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Friend of Warren
You are fine just the way it is. You just don't want it sticking out.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks guys! Whew! Once again, the simplest things - you know! I keep telling myself to take "before" pictures - before any repair - but then I forget to! I mean, what can be difficult about replacing a seal you know? Until you do it and it can be tapped further in than flush. Hmmmmm, I wonder if its supposed to be like this
Thanks again.
