can a 3.0 w/95000 mi can have 4 broken head studs ??
The motor is for sale ; Is it possible or the owner is trying to rub me ??
What is the market price for a 80 SC engine dismanteled ?? Thanks !! JD
65 coupe, Dolphin gray #1506 70S coupe, Blood orange #1436 R Gruppe #647 ; S Registry #1666 |
Four broken studs at 95K on an '80 SC is entirely possible. 1980 cars got second generation studs, and they weren't much better than the originals!
Keep the Shiny Side UP! Pete Z. |
Free minder
Absolutely possible. Mine had 4 broken studs with 110k miles. Price for a 3.0SC that needs to be rebuilt, I`d say is in the $2,500-$3,000 range, from what I've seen on evil bay.
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
ditto >> my 80 SC had three broken head studs at 225k KM
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Somatic Negative Optimist
RS-GT:
A dismantled motor can be a cat in a bag unless you get a clear history from a seller with good reputation. The studs are not the main-issue because they're going to be replaced anyway. What condition is the crank? Standard/Standard? Just needs polishing? Are the cams good? Why is it dismantled? Does it have Nikasil or Alusil P/C's? Are they re-usable? Meaning are they in spec? Especially the first land on the pistons? Can you verify the 95k Miles?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
My 80 had 120K on it when I tore it down, six of the bottom studs were steel, the rest dilivar. Some hack decided to only replace the broken studs at some point early on, and he did a piss poor job of it.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
The answer to the question is yes. Mine had 7 broken head studs at only 60,000 miles. My rebuild was considerably more than quoted above, and the rest of my motor was perfect.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
