Idenify the noise
You can hear it here:
http://members.shaw.ca/midnightluck/noise.mp3 At the time of recording: engine up to operating temperature, oil level and pressure normal, car sitting level. Same noise when engine is cold. Recently installed a used Carrera tensioners, disassembled and cleaned in ultrasonic bath which have been problem free. Tried with the fan belt disconnected but the noise is still there. Unknown mileage/time since last valve adjustment - one coming up very soon. It's coming from the driver side bank of the engine, most likely from the valve area. What do you think it is?
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
In case it wasn't clear, I'm talking about the metallic squeeling just as the engine stops turning.
how about a pic of the engine. is the smog pump gone? doesn't sound internal to me.
is there something stuck in the crankshaft pulley well? Whatever it is, it sounds dry.
1984-911 M491
Just a guess, but I would check the alternator bearing. Try again with fan belt disconnected.
1984-911 TLC......SOLD |
Make Bruins Great Again
But don't run it for long without the belt.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
As I mentioned the noise persists without the fan belt. I thought it might even be a squeeky belt but that's not it either. No foreign object in the pulley area. A/C compressor gone, never had an air pump.
