Max Sluiter
Flieger's Avatar
Looks like the car spent time as a rare Aubergine 911 from the looks of the engine fan and the cam chain boxes.
Old 07-01-2008, 07:36 PM
(the shotguns)
berettafan's Avatar
ahhh my eyes!!! pull that motor pic or make it black and white or something!!!
what's your budget?
evidence of a ***** paintjob makes the thought of stripping and repainting the original color (yet again you are a luck ****er getting irish green and that oh so cool interior color) tough to resist.
Old 07-01-2008, 07:38 PM
(the shotguns)
berettafan's Avatar
Gee, i was thinking it must've been used in some old Chess King advertisements
Old 07-01-2008, 07:39 PM
Max Sluiter
Flieger's Avatar
Originally Posted by ossiblue View Post
Congratulations! At $450 you couldn't get upside down on that car unless you gold-plated it!
Again, congratulations and welcome.
It has been gold plated, at least in the engine compartment.
Old 07-01-2008, 07:43 PM
I will definitely repaint motor trim to origional but I do have other priorities ahead of that.
Really I just want to turn the car into a solid Sunday driver. Body and paint will be addressed, we'll see how it goes.
Old 07-01-2008, 07:49 PM
Now that I've had a chance to better look @ my car I've dicovered I have the aluminum "S" calipers, vented front/rear rotors, stainless heat exchangers, and what appears to be new bursch exhaust (sticker still on it)! Not bad for $450!
All that said, my brake pedal goes to the floor (has been sitting for 7-8 years...where do I start?
If I can't tackle this myself...Can anybody in MD recommend a good Porsche shop?
Old 07-04-2008, 09:11 AM
As far as the brakes are concerned plan on replacing all the rubber lines, rebuilding the calipers and completely flushing the system with new fluid. You may want or need to rebuild or replace the master cylinder while you're at it as well.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 07-04-2008, 09:17 AM
SP2 SP2 is offline
SP2's Avatar
If the pedal goes to the floor, it is probably the master cylinder.
+1 on the rubber brake lines, front and back. Brakes are a safety priority.
+1 on rebuilding all four calipers. I would consider having that done professionally. Everything else you can do yourself. The calipers rely on a thin rubber seal, and if they haven't been used, they are probably cracked or about to.
The rotors come off easily. You could check them for thickness specs, but I would just buy new ones.
Don't forget to have the parking/emergency brake inspected.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 07-04-2008, 10:04 AM
(the shotguns)
berettafan's Avatar
Grady would say you MUST replace the mc. It's not that expensive.
Again, we need a budget to know where to point you.
Old 07-04-2008, 11:33 AM
One other thing that comes to mind (I don't know if it has been mentioned yet) before you do try to get the engine running make sure to replace all the rubber fuel lines!
Michael
Old 07-04-2008, 12:21 PM
SP2 SP2 is offline
SP2's Avatar
Michael, can you talk more about the rubber fuel lines? Is this a DIY? Thanks!
James
1981 911SC Wine Red
Old 07-04-2008, 01:49 PM
Zeke's Avatar
Why is it that unexperienced people get the $ 450 911's? If a shop has to revive this car, it won't be such a special deal by the time all the due diligence is performed. If the owner makes mistakes reviving it, it may be the next 20 K early 911 by the time it's road worthy.
I guess what I'm trying to say is.... send it to me, I'll take care of it.
The list is long and tedious, my friend.
Brakes, no 1 issue, do everything.
Gas tank and lines, or you'll hate the car every time it stops running on you.
Tires, no more needs to be said.
De bug, de insect, de rodent as nec.
Clean all elect connections.
Lube all cables and there are many.
Rebuild carbs; fuel pump may be dead too (I wouldn't trust one that has sat dry for 7 years)
Clean out behind engine fan, may very well be critters in there, dead or alive.
New battery(s)
Change tranny oil and engine oil.
Then, start the motor.
And then you can start working on the car. Whew, BTDT.
Old 07-04-2008, 02:14 PM
perfect parts car for a 69S restoration project....
Listen to Milt very good advice!
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 07-04-2008, 03:04 PM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
Whoah. Go buy a lottery ticket too! Nice find man
Old 07-04-2008, 04:31 PM
I'm not sure how many rubber fuel lines would be on a '69 with webbers, but as a general rule of thumb any rubber fuel lines on a car that old should be replaced. In addition, the tank and lines should be cleaned/flushed.
You don't want old hard/brittle fuel lines on any car. I had an '84 928 that split a rubber line from the fuel rail to the injector and sprayed fuel all over the hot cylinder head. I was very lucky it didn't start on fire, I could actually see fuel boiling on the cylinder head!
Michael
Old 07-04-2008, 06:26 PM
To answer some q's...
What is my budget? Whatever it takes to make it a solid reliable Sunday driver. Am I prepared to drop 20k in the next month, no...in the next couple years? Yes (I work long hours and have a family, can only find so much time to work on the car). Biggest question should be time line, I don't have a time line, I work on cars as a hobby, could take several years. I've bought, fixed, sold over 40 cars in the last 16 years ("mostly" water cooled VW's which I know are very basic and easy to work on). Although this is my first Porsche I am mechanically inclined and I have turned a few wrenches. I've replaced engines, transmissions, clutches, brakes, head gaskets, timing belts, etc. I am also a painter. This is a car I do not plan to flip but to hang onto and enjoy. I plan on keeping it fairly original and changing it back to Irish Green. I asked for a reputable Porsche shop in MD so I know where to send it for a once over after I get the obvious sorted out.
I will rebuild the calipers, buy a new MC and replace the rubber lines with stainless braided lines (yes I know stainless braided lines would not be original).
I've come to asking questions here because I know most of you guys have gone through what I'm about to go through. I will take all the heads up advice which will help speed this project along.
My things to do list (many sub-categories, I know):
1)Brakes
2)Steering/Suspension (everything appears tight so far)
3)Tires
4)Rust
5)Oil/Cooling
6)Fuel system
7)Drive train
Sorry for the LONG post guys, I do appreciate all the info/feedback you guys are giving me.
Old 07-05-2008, 06:58 AM
UnRegistered User
billybek's Avatar
Ya ya ya!!
Now, how about some more pictures!!!!
Bill K.
Old 07-05-2008, 10:32 AM
AutoBahned
RWebb's Avatar
IT sounds like you've answered all the questions about your ability to rescue the car (except two - [1] will you wife kill you? (and if not, will she kill you after 3-5 years of this?), and [2] what sort of space do you have?
Best, would be if you had space to separate the body and put it on a rotisserie while putting the powertrain, etc. elsewhere (away from sanding dust, paint spray, etc.) for rebuilding at the same time.
Here is a list of things from critical to minor...
http://forums.pelicanparts.com/porsche-911-technical-forum/189572-long-term-commonly-neglected-maintenance-post2955054.html#post2955054
Old 07-05-2008, 11:00 AM
beancounter
jwasbury's Avatar
Congrats. An absolutely amazing buy from the looks of it (even with the rattle can gold engine).
From the photos, that hardly looks like a project at all. Check out the thread with the guy who bought the 69s targa that sat in a field in TX for 20 years. Now that's a project car. You're in fine shape by comparison.
Old 07-05-2008, 02:22 PM
My wife has gotten used to me having a "project" in the garage. She is happy its not another VW in there. Space may be an issue. I have been looking into a rotisserie but I only have a one car garage...
There is rust through on the floor @ bottom of gas pedal which indicates leaking MC, also @ driver side floorboard near the rocker. Rest of floor looks surprisingly good.
Oh, and the motor paintjob is definitely not "rattle can" pretty sure it's basecoat with urethane clearcoat. Will definitely blast/repaint.
Old 07-05-2008, 04:21 PM
