Turn Signal Switch / Headlight Issue
I just replaced the turn signal switch in my SC and now it works fine, but my left low-beam headlight only worked for a couple of "on-ff" tests and now does not work at all. The right low-beam and both high beams work fine. I'm running H4's with stanard bulbs.
I pulled out the headight switch again and checked the connections, but it made no difference. Anyany suggestions? Thanks,
Hugh Lindberg 1972 911 1970 Alfa Romeo 1300 GT Junior |
Bad bulb?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
It turns out that the fuse was the culprit. In fact, both left and right low-beam fuses were coated with a white powder of some sort. Swapped both out and light work fine.
Good deal, Hugh!
Best, Doyle
