Turn Signal Switch / Headlight Issue
I just replaced the turn signal switch in my SC and now it works fine, but my left low-beam headlight only worked for a couple of "on-ff" tests and now does not work at all. The right low-beam and both high beams work fine. I'm running H4's with stanard bulbs.
I pulled out the headight switch again and checked the connections, but it made no difference.
Anyany suggestions?
Thanks,
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 07-20-2008, 10:48 AM
dshepp806's Avatar
Bad bulb?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-20-2008, 12:11 PM
It turns out that the fuse was the culprit. In fact, both left and right low-beam fuses were coated with a white powder of some sort. Swapped both out and light work fine.
Hugh Lindberg
1972 911
Old 07-20-2008, 12:36 PM
dshepp806's Avatar
Good deal, Hugh!
Best,
Doyle
Middle Georgia
Old 07-20-2008, 01:26 PM
