Another 915 "sloppy shifter" thread
Hi all,
I'll soon be sorting out this issue in my newly acquired '80 911 SC. I'll replace all the bushings they show here on Pelican. However the issue I'm concerned with is the shifter is not "centering" itself (i.e. you can move it to the position between 1st and 2nd and it will stay there). Basically it will flop around from the neutral position to the position between 1st and 2nd. Am I looking at more than bushings? I haven't pulled it apart yet but what should I expect? Also, the 1st gear synchro is toast. I see that this is a common problem on the 915. Should I pull that out and have it replaced or just leave it as is? TIA!
'87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
Member 911 Anonymous
OEM 915 Flop.
If you want that out, you will need a gate shift kit, like a Sienes Gate Shift Kit sold by our Host. I recently placed it in my baby and WOW what a difference.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
the 915 shifter is ONLY spring loaded from the 5th and reverse side so your shifter is acting properly
I recently upgraded to the wevo shift coupler and love it...feels more solid with less slop
Justin 84 Carrera Targa 98 F-150 4x4 |
Or you could try this fix another member documented.
<insert witty title here>
Welcome to another local guy! Drop by our weekly get-togethers behind Chapter's at Sherway Gardens, Saturday mornings at 10am.
Unfortunately, that's the way a 915 is supposed to feel. I've always said they're the weakest part of the 911. I might try that additional spring, next time I've got it all open and apart.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
oof da, that spring on the coupler is wierd...I like it EXCEPT for the fact that is applies side load on the gears always!
here is my home made contraptions... ![]() no slop delrin bushings ![]() spring loaded shift housing ![]() in work, the gate
Ed M 86' Coupe |
Just live with it -that's a 915
Almost Banned Once
Nice! Someone has a Mill/Lathe
- Peter |
![]() CNC 3 axis and 2.5 axis mill and a super presicion Hardinge tool room lathe and offline programing with solid models....its what I do
Ed M 86' Coupe |
I strongly disagree - rebuilding it even back to stock NEW parts makes a huge differance
Ed M 86' Coupe |
Ed, that is some beautiful work. I like the Derlin Bushing concept. Have you put it on your car yet?
Yea over a year, very happy with those, planning to run a few soon as I have run out from all my local friends who now also run them
Ed M 86' Coupe |
PMed U
A couple of years ago I replaced every busing in the shifter system and it was a huge improvement. I used the brass coupling bushings from our host plus the rest of the bushings that they sold. The brass transmits a little bit of noise but is very solid in feel I really like it. In my opinion this is as good as a stock shifter setup can be without going to the next level like the Seine and others.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
6 cylinder symphony
+1 on the Seine Systems gate shifter. I'm not even using the gate part - just the spring system that centers the shifter on 3-4. One thing I had to do though - I had to add a 1/4" plastic spacer to the bolt for the Seine spring. The short shift kit moved everything up so high it wasn't possible to tighten the nut on the spring bolt all the way without a spacer.
Besides the factory short shift kit, I also added the wevo coupler. Also re-did the center bushing in the linkage. All of that work - and changed the fluid (Royal Purple transmission fluid), and it is perfect. Well - as perfect as a 915 can be. Ken
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife Last edited by Kidasters; 07-30-2011 at 05:56 AM.. |
lets not make an oil thread out of this
...it's Kendall or nothing!!
Ed M 86' Coupe |
