Typical Salesman
jeffrey2's Avatar
What type of alternator do I need?
I have a 79SC and need what i believe to be a new alternator and/or regulator. I'd rather replace both just to make my life easier; but how do I know which I need...internal reg or external? Is there an easy way to tell?
Where can I get one? I see them on eBay, but not sure about that. I searched Pelican and can't find them either; so I stand to accidentally blow $150-300 on the chance the alternator will fit.
I have Wayne's book too, it says I need an alternator removal tool, by dumb luck, is that in the tool pouch? It kinda looks familiar...
Thanks!
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 08-01-2008, 01:51 PM
304065's Avatar
79SC= external regulator
do NOT get an internal reg, this was a retrograde step by Porsche.
search here for extensive details on the fix
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-01-2008, 02:11 PM
Peter Zimmermann's Avatar
Your '79 SC originally was fitted with an alternator that uses an external regulator. To determine if you still have the original type setup look at the end of the shaft that protrudes from the middle of the alternator and holds the belt pulley and engine cooling fan in place. If the shaft's end is flat you have an original type alternator, if the shaft has a recess for an Allen wrench, you already have an alternator with an internal regulator (many early cars have already been updated). In addition, the pulley nut for the alternator that uses an external regulator requires a 22mm wrench, while the alternator that uses an internal regulator requires a 24mm wrench. Not sure what an "alternator removal tool" is. Hope this helps!
Keep the Shiny Side UP!
Pete Z.
Old 08-01-2008, 02:24 PM
Typical Salesman
jeffrey2's Avatar
Okay, got a line on a new alternator, next question is...regulator. Does an alternator with external regulator include the regulator? Or do i need to purchase a regulator as well?
Thanks again &sorry for the redundant questions, but I want to do this once. (actually I paid about $500 2 years ago for this and don't want to pay that much again; nor do i want to do it again).
Old 08-01-2008, 03:31 PM
Normally an alternator with an internal regulator comes with a new regulator fitted, but an alternator that uses an external regulator does not come with a regulator.
Pete Z.
Old 08-01-2008, 03:57 PM
Typical Salesman
jeffrey2's Avatar
last question, I promise...Where is my regulator located?
Old 08-02-2008, 08:46 AM
304065's Avatar
It is located on the electrical console at the left side of the engine compartment.
'81 R65
Old 08-04-2008, 08:33 AM
Typical Salesman
jeffrey2's Avatar
Thanks, if this is the fix, then I don't need to pull the alternator, john, you're a lifesaver!
Old 08-04-2008, 10:00 AM
304065's Avatar
Why do you think you need a new alt or reg? What are the symptoms?
'81 R65
Old 08-04-2008, 11:01 AM
