How hard is it to remove an early engine??
I have to change the trans in my '71, and fix a main seal leak, but have never removed an engine. I am quite new at this. What do I need to get started? I have "101 Projects" but could use some more advise on dropping it, ie. using a jack to lower it??
Thanks.
'71 911E Targa Last edited by 911Etarga; 08-11-2008 at 03:30 PM.. Reason: sp |
sudo apt-get purge 930
There are many, many threads on this topic. Do a search for dropping an engine and you'll find a lot of great advice. It's not a hard job.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
SCWDP MEMBER #0011
You need a motorcycle jack ,some jack stands, a floor jack, easy job took mine out about 3 times, takes me about 45 mins without help, but its not hard. eng and trans.just ask if you need help
there may be a pelican near you that could offer on-site advice. But we don't know where you are!
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
19 years and 17k posts...
I did mine a few years ago and I was (and still am) mechanically "reclined" and I was able to do it. I recommend buying a motorcycle/ATV jack (I bought a $100 Sears model) and that made the job easier. Take lots of pictures as you disconnect stuff, take your time and follow the instruction in Wayne's book and in this forum, you'll do fine!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
RETIRED
Pull the engine and trans as a unit.....Wayne's book and the Bentley will help out a lot.
The oil lines can be a beeyotch. I use thin Bicycle open ended wrenches.....Park or Campagnola....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 08-11-2008 at 05:15 PM.. |
Among other things . . .
I would strongly suggest an investment in one of these . . . from our Host
911 Engine/Transmission Jack Adapter PN#PEL-PW-2563 Well worth the money. I did my first engine/trans by myself with this adapter. The motor/trans is very well balanced on this adapter and you can adjust the forward/backward angle to help you get the motor back into the car Would not do it without one . . . too much risk in dropping it. Of course, you need proper jack stands (4 minimum) and a floor jack that will accept the Adapter I mentioned above. Best of luck . . . actually removing the motor is easy, putting it back in is more time and work.
Tom Ching 69 911E |
Bunch of old cars
list the city you live in, post up a picture of a fridge stocked with beer.
poof! gone |
I'm going for it..........wish me luck. I'm sure I will have a million questions, so thanks in advance.
'71 911E Targa |
AutoBahned
it is harder than a VW; easier than anything else
do not need motocycle jack but will make it easier have a friend there & keep a cell hone with in reach - just in case you need to dial 911 - the thing is heavy... Last edited by RWebb; 08-12-2008 at 12:51 PM.. |
Motorcycle/ATV lift is not needed, but nice to have.
Special lift adapter is not needed, but nice to have. Transmission jack is not needed, but nice to have. You can also fabricate a U-shaped dolly out of construction timbers and plywood and suitable caster wheels. The wide base helps balance the engine/gearbox. Roll a floor jack under the inverted U to support the drivetain (engine and gearbox). Once the drivetrain is down, remove floor jack, then roll out the DT. Not needed, but nice to have. Some guys rest the drivetrain on a stationary pad, then lift the vehicle up and away. That works too. Wayne's book must have a checklist of parts to disconnect/remove. 911 drivetrains have been R&R'd since 1966 with nothing more than a floor jack. The above variations make the process a little more convenient, but not altogether necessary. There's more than one way to skin a cat. Sherwood |
One thing to watch. The 71 has a funky throwout bearing/clutch arm design. It has a special procedure to do the separation of the transmission from the engine. I've never done it so I don't know how hard it is. My Haynes manual describes the procedure.
-Andy
72 Carrera RS replica, Spec 911 racer |
Haynes manuals are good as jack pads. Not good for balancing the engine on the jack. certainly not good as a source of intelligent information.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
So what manual do you use for an early 911?
David 1972 911T/S MFI Survivor |
