Clutch disk differences?
Hi -
I'm replacing my clutch disk due to a trans. oil leak which contaminated the old one - which wasn't that old! I had recently installed a new Sachs power clutch w/the alumin. pressure plate. The new disk however, looks a bit different than the old one - see photos below. The old one that came w/the Sachs power clutch kit is the one with the ridges on the surface while the new one is smooth. Aside from the surfaces, are there any other differences that I should be concerned about? Thanks a lot, Tom Old clutch disk: ![]() Old clutch disk numbers: ![]() New clutch disk: ![]() New clutch disk numbers:
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Schleprock
Nothing to worry about. Standard/street clutch disc friction material is typically segmented nowadays. You shouldn't notice any difference in the clutch feel. The solid disc material is preferred for more surface area. So you're actually now going to use a "better" disc. But given the HP our engines produce? You're not going to exceed the capabilities of a segmented disc.
Kevin L '86 Carrera "Larry" |
Thanks, Tom
