Slumlord
Porsche_monkey's Avatar
I'm looking for suggestions on how to easily instal the boot. The standard answer of 'use a mustard jar lid' does not work with the jars in Canada.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-23-2008, 03:56 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I used to rebuild my A & M sized Porsche calipers once a year due to heat damage from track use. Seems every year one of the guys in our local group says they find a puddle under the front of the car at the end of the year. Heat gets the best of these front calipers after about 6-7 track days and the seals begin leaking.
Brake cooling or regular inspection is a must with these cars if you track them hard!
Kevin L
'86 Carrera "Larry"
Old 08-24-2008, 10:48 AM
In response to therotman,
I bought newly restored S calipers from Eric Shea. They had been re-anodized, had new stainless steel pistons installed, new stainless steel crossover lines, etc.
I then sold my old calipers back to him as cores. The 2 sets of calipers were the same specification of Ate aluminum S caliper for the 1971 model year.
His price was great and the work was excellent. S calipers have a higher market value than A or M calipers. The brakes work smoothly and forcefully. They can be modulated better and the pedal is positioned better for throttle blips on downshifts.
I will PM you with the price I paid.
Most calipers don't have that finish to begin with, so spending however much he charges is a bit of a waste. I got rebuilt front calipers from somewhere I'd have to look up, but it was way less than $70 each without the core charge. I rebuilt the rears myself and I thought the slightly higher price for the rebuilt ones were worth it versus the extra labor.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 08-24-2008, 01:40 PM
Max Sluiter
Flieger's Avatar
S calipers?
Old 08-24-2008, 03:11 PM
Don't forget to replace the flexible hoses and think about replacing the 28 year old master cylinder...
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-24-2008, 05:27 PM
