Trying to make my carrera 3.2 FASTER!
Well ill start by explaining what I have done so far. The car is an 88 3.2, it has fabspeed cat delete, K&N drop in filter and 911chips.com chip.
I raced my friends 04 350z which has intake, cat delete and clutch and flywheel package. from a 1st gear roll he would take me by like a car, car and 1/2. From the light I had him till the end of 4th which amazed me and made me so happy . I was very impressed, but its those rolls that were killing me. What else can be done to these motor for more power with out opening it up. I was thinking of getting the bursch exhaust but i didn't know if i would loose back pressure from having the cat delete and exhaust. Help please, thanks.
1988 Porsche 911 3.2 (cat delete, K&N drop in filter, chip) |
Lose weight...
86 Carrera 70 914-6 |
You have pretty much done what you can. You could always spend some dollars on headers and induction. But to get anything worthwhile in the HP it will run into big dollars. Headers maybe not but a better EFI and ITB's or carbs will cost in the $1000's.
Losing weight will make it a fun car to drive, but you always have to consider how much comfort you will lose and how it may affect resale.
88 carrera |
A few things.
1) A 911 is not a dragster. 2) Street racing till the end of 4th? That's very fast for the street. Just take it to the track would you please. |
Ya I'm not looking to spend thousands but ill def look into loosing weight. Where can I start first on that. Like what should i take out which will help my car loose weight.
Also with the exhaust question. Should i get one or should i just keep it stock for back pressure?
If you have the sports seats you can lose around 70lbs by putting in some light weight ones.
But for the definitive answer on losing weight..try 438 lbs gone in 5 days - My Build Story It is a comprehensive and excellent description of on how to lose weight and how much.
88 carrera |
Now in 993 land ...
Go to a road track. You'll beat any stock 05 350Z. What are you trying to do anyway? Impress someone in a 20 year younger car? The 911 is an icon, you don't own it to drag race.
That said, headers and cams would be next on your list - with an updated chip taking this into account. And loosing weight as everyone has already pointed out. You could also just go buy a 2004 996 turbo, catch up in time and forget about it. George |
AutoBahned
Start at the rear of the car. 2you can remove the bumper shocks & exchange for the Euro crush tubes or just toss the whole bumper assembly.
kill the a/c; and any big heavy metal stuff on the motor. get a FG rear deck lid... you have a penalty with the later MY car as it has the heavy G50 in it. If you like the feel of a 915, build up a late 70's Mg cased one for strength and the gear ratios you want and put that in. people will pay good money for a G50. remove the sound absorption material, again starting at the rear toss the heater blowers in ecah footwell and then the one in the rear. look at Shakingjoe's wt. loss thread it is currently active on here |
So what's the weight difference between a G50 and a "late 70's Mg cased one for strength and the gear ratios you want", and what is the net performance gain of losing said pounds that low and centerish on the car? Has anyone ever actually done the switch from G50 to 915? Not trying to be antagonistic, if there really is a significant performance gain for this I'd like to know about it.
ßrandon |
The "weight penalty" of a G50 is relatively minimal. As Randy correctly states a BUILT mag case 915 would be lighter with optimal gear ratios and the strength and dependability of a G50. But, that would be quite a pricey alternative to sticking with your already strong, reliable, sure shifting G50 that carries a small weight penalty.
My advice as the owner of an 87 G50 Carrera would be: 1. Don't race your friend on the street anymore. If someone crashed, you could end up in prison and lose EVERYTHING. 2. If you are going to keep your Carrera forever, comfort is not an issue, and resale does not matter, strip all the weight you can off that thing. My Carrera lost 400 lbs. It weighs 2,460 lbs. The result is a much more responsive, lively, fast, and noisy car. Good luck. Mike |
Brandon:
A few people have actually weighed and measured a number of G50's. You may want to search posts from Tyson Schmidt. He recorded data from several G50 and 915 cars. I believe Tyson found there was a 15-20 lb difference stock. If your 915 has an oil cooler, the difference is nil. I think there is a lighter flywheel that brings the G50 to about the same weight as a 915. The G50 is a strong transmission that is rated to survive much higher hp and torque loads than a standard 915. Mike |
Thanks Mike, confirms my suspicion. 15-20lbs reduction at that location is pointless. Changing your gear ratios is another story, although Porsche did a pretty damn good job already.
ßrandon |
a.k.a. G-man
Lose weight, take it to the track.
If you're friend starts feeling good because he's faster than a Porsche, remind him your car is 20 years old and that any recent Porsche would gladly have him for breakfast. ( heck, it even doesn't have to be that recent either.)
Сидеть, ложь, Переворачиваться |
Leave the engine alone: install close-ratio gears.
You'll be amazed at the difference,....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
On the engine side:
964 cams will prevent the car from being out of breath after 6000 rpms. A MAF system will yield approx ten more HP... Nice little boost for reasonable amount of money. Light flywheel will make the engine rev faster and contribute to overall weight reduction. |
abit off center
You guys need to go to some autox's that's where you will shine against the 350z
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
For drag racing
1) drop weight 2) install an 8:32cwp
MBruns for President
For the G-50 to 915 myth - quoted posts of people that are much smarter than me:
G-50 vs 915 Transmission Quote:
Take your buddy to a DE or autocross. Get some sticky tires. Own the 350z
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Racing on the street to the end of 4th gear? You're an idiot.
