diffs in T &,E,S cranks and heads
In my parts book for my 70 911, I noticed that the cranks and heads have different part numbers for T's and E's & S's. Valves are all the same. What are the differences?
Robo
356robo 70 T Targa Looking for a 2.2,2.4, or 89 coupe |
up-fixing der car(ma)
MFI injectors in E, S
Ports 29-32-36mm, T-E-S ...MFI system built to suit the ports Compression and cams, increasing T->E->S forged pistons in the S
Scott Kinder kindersport @ gmail.com |
yep, and as far as cranks go, the 2.2T had a non-counterweighted crank.
Not a major issue for street driven cars.
Sepia brown 1971 911T. |
Are the exhaust ports in T, E, and S heads all the same size?
If so, then I'm going to assume that the paperwork on my rebuild referring to "2 mm porting" means that the intake ports of my T heads were enlarged by 2mm, making them nearly the size of E heads. Are Weber manifolds made in different sizes to fit T, E, and S heads? Robo
Max Sluiter
Ports are different, valve diameters are the same.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max,
Are the exhaust ports in a T, E, and S head all the same size in a 2.2? Robo
Max Sluiter
yes
Max Sluiter
Sorry, I was mistaken.
1970-1971: ---------intake port diameter------exhaust port diameter 911T------32mm----------------------32mm-----Euro version, Zenith carburetors 911E------32mm----------------------32mm-----Mechanical Injection 911S------36mm----------------------35mm-----Mechanical Injection The valve diameters for all the above models were 46mm intake, 40mm exhaust. This is for factory-spec street cars according to Bruce Anderson's 911 Performance Handbook. Race cars had bigger valves, bigger ports, some had carbs, some had injection, you know the factory's way of working...
OK, so what's a "911.104.306R" head for? Thanks
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Max Sluiter
Sorry,
My reference (Wayne's Engine Rebuild Book) only lists part numbers 1974--> The cylinder heads he lists are 901.105... The R suffix is a factory replacement part, I think.
Max Sluiter
I think it is an early 911S (Mechanical Fuel Injection) replacement cylider head.
I am going by the 901.104 coming before the 1974 901.105 CIS heads. 901.104.306R I think is 911S because of the "3". My 911 VIN is 91113... (911= typ#911, 1= model year 1971, 3= S specification)
Here's a pic of one of the "911.104.306R" heads on my 2.8. I was wondering what they were since they were not shown nor listed in either of Anderson's Performance books. Thanks
Thanks Max. This is good news for me as it means no port work need be done to suit E or solex cams (when the heads get rebuilt).
Max Sluiter
I think 901.104.306.0R is different from 901.104.306R. The 0R is like a 7R case number. The .306R I think means replacement part. Are all the heads the same number?
As the pic shows, the 910.104.306.0R head is also stamped "1-70".
Flieger,
Yes, all the heads are the same.
