diffs in T &,E,S cranks and heads
In my parts book for my 70 911, I noticed that the cranks and heads have different part numbers for T's and E's & S's. Valves are all the same. What are the differences?
Robo
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 09-28-2008, 11:35 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
MFI injectors in E, S
Ports 29-32-36mm, T-E-S ...MFI system built to suit the ports
Compression and cams, increasing T->E->S
forged pistons in the S
Scott Kinder
kindersport @ gmail.com
Old 09-29-2008, 12:31 AM
deathpunk dan's Avatar
yep, and as far as cranks go, the 2.2T had a non-counterweighted crank.
Not a major issue for street driven cars.
Sepia brown 1971 911T.
Old 09-29-2008, 04:43 AM
Are the exhaust ports in T, E, and S heads all the same size?
If so, then I'm going to assume that the paperwork on my rebuild referring to "2 mm porting" means that the intake ports of my T heads were enlarged by 2mm, making them nearly the size of E heads.
Are Weber manifolds made in different sizes to fit T, E, and S heads?
Robo
356robo
70 T Targa
Old 09-30-2008, 08:05 AM
Max Sluiter
Flieger's Avatar
Ports are different, valve diameters are the same.
Old 09-30-2008, 01:52 PM
Max,
Are the exhaust ports in a T, E, and S head all the same size in a 2.2?
Robo
356robo
70 T Targa
Old 09-30-2008, 02:07 PM
Max Sluiter
Flieger's Avatar
yes
Old 09-30-2008, 02:32 PM
Max Sluiter
Flieger's Avatar
Sorry, I was mistaken.
1970-1971:
---------intake port diameter------exhaust port diameter
911T------32mm----------------------32mm-----Euro version, Zenith carburetors
911E------32mm----------------------32mm-----Mechanical Injection
911S------36mm----------------------35mm-----Mechanical Injection
The valve diameters for all the above models were 46mm intake, 40mm exhaust.
This is for factory-spec street cars according to Bruce Anderson's 911 Performance Handbook.
Race cars had bigger valves, bigger ports, some had carbs, some had injection, you know the factory's way of working...
Old 09-30-2008, 08:21 PM
PCA7GGR's Avatar
OK, so what's a "911.104.306R" head for? Thanks
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 09-30-2008, 08:43 PM
Max Sluiter
Flieger's Avatar
Sorry,
My reference (Wayne's Engine Rebuild Book) only lists part numbers 1974-->
The cylinder heads he lists are 901.105...
The R suffix is a factory replacement part, I think.
Old 09-30-2008, 08:51 PM
Max Sluiter
Flieger's Avatar
I think it is an early 911S (Mechanical Fuel Injection) replacement cylider head.
I am going by the 901.104 coming before the 1974 901.105 CIS heads.
901.104.306R I think is 911S because of the "3". My 911 VIN is 91113... (911= typ#911, 1= model year 1971, 3= S specification)
Old 09-30-2008, 08:55 PM
PCA7GGR's Avatar
Here's a pic of one of the "911.104.306R" heads on my 2.8. I was wondering what they were since they were not shown nor listed in either of Anderson's Performance books. Thanks
Sergio
Old 09-30-2008, 09:02 PM
1970-1971:
Thanks Max. This is good news for me as it means no port work need be done to suit E or solex cams (when the heads get rebuilt).
Old 10-01-2008, 05:02 AM
Max Sluiter
Flieger's Avatar
I think 901.104.306.0R is different from 901.104.306R. The 0R is like a 7R case number. The .306R I think means replacement part. Are all the heads the same number?
Old 10-01-2008, 11:38 AM
PCA7GGR's Avatar
As the pic shows, the 910.104.306.0R head is also stamped "1-70".
Sergio
Old 10-01-2008, 01:52 PM
PCA7GGR's Avatar
Flieger,
Yes, all the heads are the same.
Sergio
Old 10-05-2008, 07:56 AM
