Large Registered Member
30 mpg... Yes!
It was on a long distance trip from L.A. area to Reno up Hwy 395 averaging 80-90 mph. This was even before I had the headers on, but had brand new fuel injectors, and a SW chip. You might be in for a pleasant surprise if you have your injectors rebuilt or replaced with new. My MPG improved dramatically after doing so with the addition of a SW Chip!!!
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
86 Carrera Coupe
Location: Holyoke, Massachusetts (western end of state)
Already got the SW chip. Also my mpg doesn't change with the AC on probably because I have all the windows closed and sun roof closed. I agree with going slower on the hiway will increase mpg but I want to get there so I was just wondering if I was missing anything that might help. Seems I have all the bases covered and I'm doing OK on mpg. I had considered a positive forced ram air, using a fan and ducting it to my air cleaner intake but that post seemed to go nowhere. I even have the aero mirrors instead of the flag mirrors to cut down on drag not to mention I think they look better.
http://www.fueleconomy.gov/FEG/bymake/Porsche1988.shtml
Rick 88 Cab |
The efficiency of the A/F ratios and the fuel injector performance makes this possible. Steve has the magic ratio's set up in his chips for fuel efficiency at cruise. How many miles on your engine? If it has high miles, and you've got the oem injectors, time to have them overhauled!!!!!!! Not only will your engine gain power, it will be far more efficient on the mpg side! ask me how I know....
How come the top part of the gas tank gets more miles per gallon than the last part? I was heading for 30 mpg, then had to switch to short trips and city driving over the weekend which killed it.
Is it the Reserve part of the dial? CIS fuel consumption, what is normal?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I saw 27 MPG on my trip to Parade this year. That was on 100% gasoline. The ethanol blend fuel in that part of the country dropped that a several MPG. On the track for the DE I used 1/2 a tank of fuel in less than one hour of driving. WOT takes a lot of gas, but provided big grins.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
MBruns for President
My last track excursion - it was hot - 9.72 MPG
Me after the day filling up
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
is it the picture... or is your oil pressure a bit on the low side? |
I think it's bound to be a tad lower than that when driving for almost an hour, but I could be wrong. Looks like 23 to 3,000 to me in the picture.
My 3.0 SC gets 27 to 28 mpg @ 2800 rpm @ between 60 and 65 mph on premium gas.
the numbers are on some threads around here somewhere.. I have the updated restrictors and I get 1 bar at warm idle.. and then seems to be above 3 bar most all the time when driving... I can't remember to tell you the truth... you might see if others with your car have that oil pressure at that rpm. Could probably throw out a post....and see. I mentioned in case you didn't notice or it was a recent lower reading.
I get 20 with very mixed driving, and 21-22 at 100mph on the autobahn although I suspect it's in dire need of the valve adjustment I'm going to give it this weekend.
'84 911, some sort of red color '05 Subaru WRX wagon |
I get about 28 MPG bone stock.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
does twin plugging help mpg? i would think that if you are getting a more complete combustion that less total gas is needed.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
you see Arthur...
I can get about 27 mpg in my 82 SC, with cat bypass, but its usually lower, cause I have a hard time keeping me foot of the go fast pedal
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
The drag force increases as a function of the velocity squared.
Drive 80 mph instead of 65 mph and there is a whole lot more drag to overcome and a lot less mpg's. If someone would please tell Obama this, maybe in addition to inflating our tires properly, if we went back to the Jimmy Carter 55 mph speed limit we could cutback enough on foreign oil consumption we could sell the excess to China and fund US Government run health care and early retirement for all. Heck, if we lowered the speed limit to 35 mph we could save enough oil to all be able to work 25 hrs per week and retire at 50 like they do in France.
crude rudy '84 cab '14 ZX-14R |
during the last 55mph law.. I hated it.. with my new BMW 2002... :-) and 40cent gas
now it doesn't seem like a bad idea... retire and go to the track for fun |
Bone stock, now at 120,000mi. 17-20 in town, and the best has been 27 highway running between 65 and 90mph over a 200 mile trip. The 10% ethanol isn't helping matters any! Man, I think that's great!
Karl 88 Targa |
my 80 sc - - lately i've been doing mostly city driving and im hitting around 18... on the trip down here i averaged 87mph and got 24.9 mpg.... i guess its not too bad .... but how come when i go 65 im only getting 22mpg???
2007 997 1998.5 Ram 2500 Cummins |
I thought it would be an indicator that something was wrong with the car if it started going south. Turns out the legislature and EPA (ozone level requirements) have much more effect on my MPG than how I drive or the parts I put in the car. I have also noticed that the tank to tank MPG calculations vary +/- 5 MPG from what I think they should be due to when the shutoff on the vapor recovery pump works. For richde in germany that is a lot of work to go from liters and kilometers to miles and gallons. I like the BMW commercial where they show a BMW going by a gas station in a small town in southern Germany and the price is $9 per gallon. Shouldn't it read like $1.45? And my 2003 WRX sedan 5MT has gone 108235 miles and used 4661.420 gallons of gas for an MPG of 23.219 MPG probably similar to your 2005.
Rick 88 Cab |
