Can't get 13/16 socket to come off after spark plug install
Is there a narrow spark plug socket available ? I just replaced my ignition wires , distributor cap and rotor and thought I might as well do the plugs too. I did all the plugs and on the last one , the number one cylinder , I could not get the socket to release. I used a normal 13/16th spark plug socket with an extension and a flex head ratchet . Is there a trick here ? I left the # 1 'till last because it looked like the easiest one to do ...
Thanks, R
Rob G 1975 911S Targa 1999 GMC Sierra SLT "Vintage" Bow Rider |
spark plug socket
I have had the same problem before. I had to unscrew the plug to get the socket out and then grind down the OD of the socket to get just a little more clearance. The other thing I do is duct tape the socket to a u-joint and a short extension and I then have a dedicated set up. I am sure there are special tools for this but this is what I have been using for years.
Donn |
Most standard sockets get jammed up tight against the back of the chain box on the #1 plug, and sometimes the oil cooler on the #6 plug. There are narrow sockets available, or you can just grind down the top of the one you have until it clears. I did that and welded it to a 3" extension, so there is no chance of it falling off of the extension and getting trapped under the valve cover.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Soldier of Fortune
If you have it, use the spark plug wrench in the Tool kit Porsche provided with the car. It is perfect for the job.
Thanks guys,
I am new to porsche and thought that I was completely inept. I'm relieved to know that this a typical problem. I had duct taped the socket connections ( several times) but that didn't work because of the standard width of the socket . Grinding it is a good idea. I'll try that tomorrow. I am in the process of trouble shooting a miss fire . After removing all the plugs it looks like the culprit is the # 6 cylinder. It's fould I'm hoping it is an electrical issue. Thanks
I recently bought the car and the tool kit was already toast. Does anyone know where to find a factory plug wrench ??
This thread shows what several of the factory wrenchs look like. OEM spark plug tool for 911
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-25-2008 at 10:53 PM.. |
Is that the factory tool in DasBoots post ?? Your post has no link...
Thanks , Harry ,
I noticed that too. Post is updated. Sorry for the "senior moment".
Here's one: FS : Toolkit, Blaupunkt , Speaker Grill, Literature
Not so pretty but it looks functional. You can prolly clean them up to look presentable.
