raoulcasablanca's Avatar
Can't get 13/16 socket to come off after spark plug install
Is there a narrow spark plug socket available ? I just replaced my ignition wires , distributor cap and rotor and thought I might as well do the plugs too. I did all the plugs and on the last one , the number one cylinder , I could not get the socket to release. I used a normal 13/16th spark plug socket with an extension and a flex head ratchet . Is there a trick here ? I left the # 1 'till last because it looked like the easiest one to do ...
Thanks,
R
Rob G
1975 911S Targa
1999 GMC Sierra SLT
"Vintage" Bow Rider
Old 10-25-2008, 08:08 PM
spark plug socket
I have had the same problem before. I had to unscrew the plug to get the socket out and then grind down the OD of the socket to get just a little more clearance. The other thing I do is duct tape the socket to a u-joint and a short extension and I then have a dedicated set up. I am sure there are special tools for this but this is what I have been using for years.
Donn
Old 10-25-2008, 08:45 PM
Most standard sockets get jammed up tight against the back of the chain box on the #1 plug, and sometimes the oil cooler on the #6 plug. There are narrow sockets available, or you can just grind down the top of the one you have until it clears. I did that and welded it to a 3" extension, so there is no chance of it falling off of the extension and getting trapped under the valve cover.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-25-2008, 08:56 PM
Soldier of Fortune
DasBoot's Avatar
Old 10-25-2008, 08:58 PM
HarryD's Avatar
If you have it, use the spark plug wrench in the Tool kit Porsche provided with the car. It is perfect for the job.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-25-2008, 10:34 PM
Thanks guys,
I am new to porsche and thought that I was completely inept. I'm relieved to know that this a typical problem.
I had duct taped the socket connections ( several times) but that didn't work because of the standard width of the socket . Grinding it is a good idea. I'll try that tomorrow.
I am in the process of trouble shooting a miss fire . After removing all the plugs it looks like the culprit is the # 6 cylinder. It's fould I'm hoping it is an electrical issue.
Rob G
1975 911S Targa
1999 GMC Sierra SLT
"Vintage" Bow Rider
Old 10-25-2008, 10:36 PM
I recently bought the car and the tool kit was already toast. Does anyone know where to find a factory plug wrench ??
Rob G
1975 911S Targa
1999 GMC Sierra SLT
"Vintage" Bow Rider
Old 10-25-2008, 10:39 PM
HarryD's Avatar
They come up here from time to time or they show up on E-bay.
This thread shows what several of the factory wrenchs look like.
OEM spark plug tool for 911
Harry
2020 MB E350 4Matic
Old 10-25-2008, 10:48 PM
Is that the factory tool in DasBoots post ?? Your post has no link...
Thanks , Harry ,
Rob G
1975 911S Targa
1999 GMC Sierra SLT
"Vintage" Bow Rider
Old 10-25-2008, 10:52 PM
HarryD's Avatar
Thanks , Harry ,
Yeah,
I noticed that too. Post is updated. Sorry for the "senior moment".
Harry
2020 MB E350 4Matic
Old 10-25-2008, 11:20 PM
HarryD's Avatar
Here's one: FS : Toolkit, Blaupunkt , Speaker Grill, Literature
Not so pretty but it looks functional. You can prolly clean them up to look presentable.
Harry
2020 MB E350 4Matic
Old 10-25-2008, 11:23 PM
