Bouncing tach
Upon shifting, tach bounces more than it did, ought. I have seen this before but don't recall the source. About to fail CD box? Any Ideas.
Old Tee all 911s sold |
Slumlord
I think this has been tied to a generator issue, voltage control IIRC.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Matt
ground strap on top of transmission. If not that, voltage regulator, in which case check also your battery box for acid spray and corrosion, rinse with 10% baking soda solution and flush with clear water...
79 SC Targa 87 m491 Targa 73 BMW 3.0 CS 73 BMW R75/5 88 BMW M6 |
Ya, mine does this as well every time I shift. I think it has something to do with a broken spring inside the tack.
Slumlord
The defective damper suggestion sounds as believable as anything.
