I would rather be driving
Have you checked end weights on the rods to determine which end to shave? That would be my next step.
It easy to see your outlier on the pistons.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
3 restos WIP = psycho
Jamie, I see your point, but the rods are coated with oil shedding coating, so I am hesitant to start grinding. I'd prefer to work on the pistons. Not to mention, the R&R rods are pretty brutally perfect...you should see them. The put Carillos to shame.
Here are the weight-matched assemblies (g): Pistons Rods Pins Total 419.9 538.1 108.9 1066.9 419.9 538.6 109.0 1067.5 419.9 539.1 109.0 1068.0 419.6 539.1 109.1 1067.8 419.4 539.1 109.1 1067.6 418.5 539.2 109.1 1066.8 1.2g delta is the max (heaviest to lightest) when the assemblies are matched for weight, but even smaller when you compare the deltas for weight matched assemblies on opposite sides of the crank: bank1 bank2 bank3 0.2g 0.1g 0.1g Is it even worth trying to get all parts to zero delta? Seriously, .2g net...
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Mmmmmmm...titanium wrist pins:
Diameter__Length___Wall____Weight .866"_____2.500"___.206"___76g 76g for the pins shaves ~33g from each end of the rotating assembly. Only $100/ea ![]() http://pppcenter.com/pinprices.html
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 11-02-2009 at 09:12 PM.. |
Well, yea, that IS a good question. Big picture, I'd have to think some assemblies will have more oil on them than others at any particular point, and that difference alone would, I think, be more than .2G.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Kenik,
I think the overall balance is great. 0.2g will not be noticeable and it is certainly a tighter tolerance than factory spec. I was referring to the end weights of the rods. I don't expect any differences but you have gone this far you might as well check. The one piston that was a gram lighter then the others caught my attention. I did not realize you had a rod that weighed enough to compensate. I would think that the difference in piston mass would be more highly "weighted" than the difference in rod mass. Remember, the piston/pin assembly is always in full 1D motion. The rod weight will be partially offset by the crank angle since it is attached to both the crank and the piston. Will it make any difference based upon the sum numbers you have posted? Probably not. would I personally spend a few moments considering the impact. Yes. Would I then act upon this thought. likely not. I guess it just comes down to not liking the one single light rod and one single light piston. I know the rpm level you are going to run the motor. IMHO, Anything you can do to increase balance at that engine speed will pay dividends in longevity.
So you changed your mind again?
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
No, all is the same as the last time we talked. Some things just haven't been updated. I'll share more as things progress. Right now, it is all about the short block assembly.
air+fuel+spark
subscribed.
Just for sport, I am curious if someone out there has the piston velocity numbers say at Keniks peak rpm and what the resulting forces would be once you plug in the weight differential across the pistons. Fun build!
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle R Gruppe #653 |
@7800 RPM
Piston Speed 3377.953 FPM Piston Speed 56.299 FPS I will need to find teh formula for force at crank angle...
air+fuel+spark
Unverified google'd list I lifted off of a VW forum which makes for some interesting reading/comparisons. The thought of making 40+ year old technology spin up to 8k is very intoxicating. Go Kenik Go!
1. Honda S2000: Engine Code: F20C1 Bore/Stroke: 3.43" X 3.31" Redline: 9000rpm Piston Speed: 4965 Ft/min 2. Lamborghini Gallardo Engine Code: N/A Bore/Stroke: 3.25" X 3.65" Redline: 8000rpm Piston Speed: 4866.67 Ft/min 3. Acura Integra Type R Engine Code: B18C5 Bore/Stroke: 3.19" X 3.43" Redline: 8400rpm Piston Speed: 4802 Ft/min 4. BMW M3 (Germany) Engine Code: S54 Bore/Stroke: 3.43" X 3.58" Redline: 8000rpm Piston Speed: 4773.33 Ft/min 5. Honda S2000 2004 Engine Code: F22C Bore/Stroke: 3.43" X 3.57" Redline: 8000rpm Piston Speed: 4760 Ft/min 6. Honda Integra Type R (JDM) Engine Code: K20A Bore/Stroke: 3.39" X 3.39" Redline: 8400rpm Piston Speed: 4746 Ft/min 7. Acura Integra GSR 2001 Engine Code: B18C Bore/Stroke: 3.19" X 3.43" Redline: 8200rpm Piston Speed: 4687.67 Ft/min 8. Saleen S7 Engine Code: N/A Bore/Stroke: 4.13" X 4.00" Redline: 7000rpm Piston Speed: 4666.67 Ft/min 9. Acura TSX Engine Code: K24A2 Bore/Stroke: 3.43" X 3.90" Redline: 7100rpm Piston Speed: 4615 Ft/min 10. Suzuki Hayabusa Sport Prototype Engine Code: W701 Bore/Stroke: 3.19" X 2.48" Redline: 11000rpm Piston Speed: 4546.67 Ft/min 11. Honda Civic Type R Engine Code: B16B Bore/Stroke: 3.19" X 3.03" Redline: 9000rpm Piston Speed: 4545 Ft/min 12. Toyota Celica GTS / Matrix XRS 2001 Engine Code: 2ZZ-GE Bore/Stroke: 3.23" X 3.35" Redline: 8100rpm Piston Speed: 4522.5 Ft/min 13. Honda Prelude Type S (JDM) Engine Code: H22A Bore/Stroke: 3.43" X 3.57" Redline: 7500rpm Piston Speed: 4462.5 Ft/min 14. Acura RSX Type S Engine Code: K20A2 Bore/Stroke: 3.38" X 3.38" Redline: 7900rpm Piston Speed: 4450.33 Ft/min 15. Ferrari 360 Modena (incl. Challenge, Stradale, etc) Engine Code: N/A Bore/Stroke: 3.35" X 3.11" Redline: 8500rpm Piston Speed: 4405.83 Ft/min 16. Lamborghini Murcielago Engine Code: N/A Bore/Stroke: 3.43" X 3.42" Redline: 7600rpm Piston Speed: 4332 Ft/min 17. McLaren F1 Engine Code: N/A (BMW V12) Bore/Stroke: 3.39" X 3.43" Redline: 7500rpm Piston Speed: 4287.5 Ft/min 18. Renault Clio 2.0 RS 2003 Engine Code: F4R Bore/Stroke: 3.26" X 3.66" Redline: 7000rpm Piston Speed: 4270 Ft/min 19. Porsche 911 GT3 RS 2004 Engine Code: N/A Bore/Stroke: 3.94" X 3.01" Redline: 8500rpm Piston Speed: 4264.17 Ft/min 20. Pagani Zonda C12S Engine Code: M120 7.3 AMG Bore/Stroke: 3.6" X 3.64" Redline: 7000rpm Piston Speed: 4246.67 Ft/min 21. Peugeot 206RC 2004 Engine Code: EW10 J4 S Bore/Stroke: 3.35" X 3.46" Redline: 7300rpm Piston Speed: 4209.67 Ft/min 22. Porsche Carrera GT Engine Code: N/A Bore/Stroke: 3.86" X 2.99" Redline: 8400rpm Piston Speed: 4186 Ft/min 23. Acura NSX-T Engine Code: C32B Bore/Stroke: 3.66" X 3.07" Redline: 8000rpm Piston Speed: 4093.33 Ft/min 24. BMW M5 2002 Engine Code: S62 Bore/Stroke: 3.70" X 3.50" Redline: 7000rpm Piston Speed: 4083.33 Ft/min 25. BMW M5 E60 Engine Code: S65 (?) Bore/Stroke: 3.62" X 2.96" Redline: 8250rpm Piston Speed: 4070 Ft/min 26. Nissan Primera W20V Engine Code: N/A Bore/Stroke: 3.39" X 3.39" Redline: 7200rpm Piston Speed: 4068 Ft/min 27. Ferrari Enzo Engine Code: F140 Bore/Stroke: 3.62" X 2.96" Redline: 8000rpm Piston Speed: 3946.67 Ft/min 28. Ferrari 575 Maranello Engine Code: 650 V21 Bore/Stroke: 3.50" X 3.03" Redline: 7750rpm Piston Speed: 3913.75 Ft/min
For reference: 66mm = 2.5984"; 85mm (my bore) = 3.3465"
The only engine that compares is the Hayabusa! You have to love the sane piston speeds a 66mm stroke brings. That said, the old school JE pistons are not nearly as light as X-member skirtless flat top pistons, like in more modern cars. This is where the piston forces come into play. Also, since the 911 is 2 valve, you have interesting dynamics to deal with in terms of valve train momentum that doesn't exist in 4 valve heads. Only the Vette motor (assuming this is what the C7 uses) has 2 valve heads from what I can see above and those new Vette's use titanium valvegear and lower engine speeds (assisted by huge displacement) to manage valve float.I would love to get some scaled down GT3 heads!
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 11-04-2009 at 03:39 PM.. |
66x127x7800
Hope my calcs are right....
66 stroke + 127 rod + 7,800 rpm = 27,738 m/s^2 peak acceleration (about 2,800 G's) Careful tightening those conrod nuts....
You missed one thing - the rods are GT3 spec, 130mm.
130mm ---> 27,606 m/s^2 (not a great difference, but every bit helps)
air+fuel+spark
Thanks for the numbers jcge!
![]() I don't think it's worth it, for an F1 engine, yes.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Damn, John! NICE spreadsheet. You are even using the Porsche font!
Man this is a good "how to" video on balancing rods:
air+fuel+spark
Kenik, all you have to do is build your conrod weight or massing jig and buy a belt sander
![]() Great vid.
Well, I am a bit of a multistasker, so I am setting down the motor bits until I can get access to my buddy's cc'ing fixture.
As you will recall from the first page of this thread, I did some pretty serious surgery to the rear fenders. The process of attaching a set of nice '69 fenders has been dependent upon my getting around to fitting tires to my wheels, for fine tuning of the fender placement. Well, I finally got around to it. ![]() This was the best deal out there, given my tire size preferences, meaning narrow body and vintage high sidewall (meaning NO 205/55/15 and 225/50/15 combos): Bridgestone Potenza RE960AS Pole Position Currently Available Prices and Sizes They are damned near the equal of the Michelin Pilot Sport (which can't be had in our fitments anymore). $315 for a set of 4 and great traction/reviews: ![]() I kept thinking I would buy the Avon CR6ZZ tires, but FOUR of these tires cost as much as ONE of the CR6ZZs...decision made. Their speed rating isn't great, but I won't ever see any road speeds above what these tires are rated, so it is an academic point. Anyhow, below are my newly mounted wheels and tires: all are widened deep sixes with the 7R offset. The fronts are 7" wide (7R spec) and the rears are 7.75" wide (what I call 8R spec ). These will fit under the narrow body fine and I could have gone 7R all the way around, but really wanted to dial in the sidewall "bulge" to be identical, front to rear. All wheel work, of course, done by Harvey Weidman.![]() ![]() ![]() ![]() ![]() Next, I will need to procure some 100mm studs and install on all 4 corners so I can fit the wheels. I will start fitting the rears by stacking 7mm spacers for test fit, then shim up the studs with washers until I get the wheels to just clear the fenderwell hardware. Then if the critical dimension is under 21mm, I'll take my turbo spacers to be turned down to the final dimension of the spacers/washers. If larger than 21mm (I am pretty sure it isn't), then I will need to source some larger spacers or check the viability of stacking spacers (initial gut check = not a good idea). Finally, I'll mark my studs, remove them, then turn them down to a nice flush fit for the lug nuts. From there I can section the rear fenders to fit my panels and trim the panels to fit. With the help of a few welding clamps, I should have the fenders ready for test fit, then it is just a few tack welds and time to get TIGing. Some will comment that this combo leaves me a bit undertired, but I just don't care. So THERE! If it is half as fun as the 165 tired, 2.7 twin plugged hot rod that was in one of the British 911 mags this month, I'll take it.I will of course share pics when available.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 11-09-2009 at 03:19 PM.. |
