mack6820's Avatar
are headers interchangeable? 3.0,3.2,3.4
I'm wondering if headers are interchangeable between the engines. Someone mentioned he had 993 headers on a 3.0 I think. What would be the best for a 3.0 with heat?
Thanks in advance!
Mack
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 11-05-2008, 07:12 AM
Bill Verburg's Avatar
yes, w/ a few caveats
993 right side collectors have a bolt pattern that is rotated 90* from all previous designs, but idf you cut the welds and rotate the ends they are interchangeable.
Some designs used different oil routing schemes
some designs can interfere w/ the clutch helper spring.
Bill Verburg
Old 11-05-2008, 07:40 AM
mack6820's Avatar
oh, ok, so the overall distance and dimensions for the exhaust ports are all the same? except for the 3.4. So will a 3.2 header fit on a 3.0?
Dont know why but Ive noticed they are cheaper to buy.
Old 11-06-2008, 06:30 AM
interchangable doesn't also mean that the header diameter is optimal for each of those motors. The 1.5" might be right for the 3.0 and the 1 3/4 diameter might be right for the 3.2. You might need to supply a few more details. All headers do not deliver increased hp results (when you put too big a pipe on too small a motor or vice versa).
Tony G
2000 Boxster S
Old 11-06-2008, 08:22 AM
From 2 thru 3.8 the spacing is the same
yes, a 3.2 header will fit on a 3.0 again a caveat, early 3.0s used thin flange manifolds w/ short studs, from ~'78 up they all used thick flange manifolds w/ long studs. You can change studs or use washers to accomodate.
Bill Verburg
Old 11-06-2008, 08:41 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
I'm reviving this thread because I currently have my engine out and am looking for some used heat exchangers. My 81 SC (ROW) has the thin flange exchangers. If I swap out all of the studs for longer, can I put thick flange exchangers on it? I have heard that there is a lip on the thick flange exchangers that will interfere with the exhaust port in the heads on my SC.
Good thin flange exchangers appear to be hard to come by, so I'd like to try to use the thick flange ones.
1981 SC ROW Coupe
Old 12-23-2008, 10:22 AM
Yes, there is a lip, if it's an issue it can be removed.
You can see it here,
Bill Verburg
Old 12-23-2008, 11:20 AM
Head416's Avatar
Question
Hijack (...but I think he got his answer, so I'll be able to sleep tonight)
Can anybody tell me where exactly is the 1.5" dimension? (Talking 3.0 here.) Is this the ID at the flange, right at the opening where it connects to the heads? Or is this the diameter a couple inches into the tubing itself at the inlet side? Or are they the same?
To state another way: For a 3.0, does the ID increase at the flange to 1.5"? Or is it a consistent 1.5" ID?
Is the tubing a 1.35" ID by any chance? (Am I making any sense? )
Thanks.
Aaron
'81 911SC RoW Targa
Old 01-02-2009, 10:25 AM
Originally Posted by Head416 View Post
....Can anybody tell me where exactly is the 1.5" dimension? (Talking 3.0 here.) Is this the ID at the flange, right at the opening where it connects to the heads? Or is this the diameter a couple inches into the tubing itself at the inlet side? Or are they the same?
Thanks.
The primary pipes are 1.5" OD, If my memory is any good that's 1 3/8" ID(I can get the exact measurements when i can get to my main computer). The collector is bigger, again do't have the dims on this laptop.
Bill Verburg
Old 01-02-2009, 11:15 AM
Head416's Avatar
Bill, you are exactly who I was hoping to hear from... thanks for your help!
So... can I conclude that I can grab any early exhaust (say '69-'74) and bolt it on?
I'm basing that on the following:
- I have a RoW '81 911SC, therefore thin flange
- My O2 sensor is disconnected, so the bung doesn't matter
- ID of 1-3/8" tubing for a 3.0 seems to match
Am I missing anything important here?
Thanks again.
Aaron
'81 911SC RoW Targa
Old 01-02-2009, 11:31 AM
Thanks again.
The SSI's that most are using today are slightly different is design and materials from the oem '69-74 header/heater boxes.
The modern SSI is much superior in design and materials.
That said, yes, you can use any of the '69-74 oem header/heater boxes on a 3 liter. The biggest concern is corrosion that would allow exhaust gas(CO) to leak into the cabin heat supply. The earliest oem header/heater boxes were not ss and would rot allowing this dangerous condition to develop, as the years wore on, better materials were used, toward the end approaching SSI for quality but never quite getting there.
Bill Verburg
Old 01-02-2009, 12:54 PM
Head416's Avatar
Does anybody know if there was a version that had a 1.35" inner diameter? I'm talking to a guy about buying his and he measured the ID as 1.35" (not at the flange, but down into the tube a little).
1 3/8" = 1.375"... seems awfully close to 1.35", but I don't want to "upgrade" to smaller tubes.
Thanks again.
Aaron
'81 911SC RoW Targa
Old 01-02-2009, 01:52 PM
