Paul K's Avatar
Need help with front targa seal replacement
All:
Just got my new targa seal from Dan Petchel. I went to remove the old one, and it turns out there are two separate rubber pieces along the top of the windshield- the thick seal part (like I just got from Dan) and this thinner strip which runs along the leading edge, as shown below;
Do I just install the piece Dan sent me (as seen laying on the windshield) or should I try to replace the thinner strip also?
Thanks in advance,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 11-15-2008, 01:51 PM
Happiest when Tinkering
gsmith660's Avatar
That is a fix to eliminate wind noise
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-15-2008, 02:20 PM
HarryD's Avatar
I would e-mail Dan and ask but it looks like the seal in the lower part of the page gsmith posted.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-15-2008, 02:25 PM
gsmith660's Avatar
Thats what it is.
Old 11-15-2008, 02:26 PM
Paul K's Avatar
Thanks guys. I now know the extra trim piece was added by the factory. I just talked with Dan Petchel- it sounds as though there may be a trim part missing from my car?
More pics in this thread;
Do I need to replace my targa seal?
Thanks,
Paul.
'83 SC Coupe SOLD
Old 11-15-2008, 02:39 PM
Paul K's Avatar
Update:
I got both old seals off. I test-fitted the new seal, and it barely stays in the channel across the top of the windshield, and feels like it might fly out at speed. I have read that glue should be used on the door seals, should I glue the whole thing? Also, I test-fitted the targa top, and now have a big gap across the front. I suspect this will cause a lot of wind noise. Can I adjust the top forward or should I put the second seal back in there?
Pics;
Thanks in advance,
Paul.
'83 SC Coupe SOLD
Old 11-15-2008, 04:58 PM
HarryD's Avatar
Paul,
It looks like you need to adjust your top forward. How does the rear fit?
Harry
2020 MB E350 4Matic
Old 11-15-2008, 05:09 PM
Paul K's Avatar
Harry:
It looks to me like it sits too low and too far back in the rear. You can (kinda) see it in my second pic in the last post.
Thanks,
Paul.
'83 SC Coupe SOLD
Old 11-15-2008, 05:12 PM
