Help CA smog fail
I have 1976 911S, 2.7L CIS. Stock motor. I have an LM-1/ aux box. I set the mixture at 14.7AFR at idle, smog pump belt disconnected. The timing and the idle was set at factory settings. When I connected the smog pump belt the AFR jumps up to 18.2 AFR at idle.
I when and had the P-car smog and it fail the CO(%) at 15 mph was 3.97 (max is 1.41) and at 25 mph 2.56 (max is 1.21). Any suggestions? What am I doing wrong setting the mixture for smog? Please help, Thanks, Ken
2001 Nissan Frontier 1976 Porsche 911S Wide Body 1992 Dodge Carivan 1989 Mazda B2200 1978 Jaguar XJ6L W/chevy 350 1973 Jeep CJ5 1970 Datsun 240Z |
I take it moving is out of the question?
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
I like Ca, but I hate the smog laws.
Ken
Seems like your LM-1/ aux box is way off as the CO test numbers indicate you're mix is way rich.
1976 in Cal., as Maxwell Smart would say, "Missed it by that much."
Dog-faced pony soldier
The over-regulation in CA is slowly making it unlivable.
I'm SO happy I have a pre-'75 911 (and a pre-'75 914). I'm actually considering getting rid of my 944 simply because it's not smog exempt and I'm sick of dealing with the B.S. and extra cost of getting it checked every year, but I also don't want to give the state the satisfaction of making me get rid of the car, which is what they want (I get an "offer" to buy the car every year from them for like $300 or something ). Anyway, I think high CO can be indicative of a rich condition or too cool running or bad cats and high HC is almost always a rich condition. I think - there's some info around elsewhere on this board about it. In any case I know you probably don't want to do this on a mag. case, but it'd probably benefit you to run it really hot before the check. And hook up the smog pump. That'll lean it out some.
A car, a 911, a motorbike and a few surfboards Black Cars Matter Last edited by Porsche-O-Phile; 09-28-2008 at 08:38 AM.. |
You could always get out the 3mm allen and back off the mixture so when you give your tailpipe a quick sniff, you won't pass out.
I will recalibrate the O2 sensor and adjusted the mixture to a leaner mixture. So to many CO indicate to rich.
SMOG Failure in California
I have a 1979 911SC (265k miles on car and 160k miles on the 3.0 liter engine) that failed smog about a month ago. I had changed out NEW the spark plugs, ignition wires, rotor, cap, air filter, smog pump air filter. I had the valves adjusted, reset timing and put in a good used smog pump . . . AND I FAILED !! . . . too rich was the results. I was thinking it may need a new cat, since it was 1979 vintage original!!?? The tech indicated to me that everything seemed fine and that he thought that my smog pump was NOT pumping enough air to dilute the exhaust gases. I therefore had a rebuilt pump already at hand to install. I got retested and it passed with flying colors. Whew . . . good for another 2 years! . . . and imagine I have one broken head stud that I still should fix . . . !! Good luck, Hz ![]() ![]() ![]() 28sep08
1979 911SC Targa 1979 930 Turbo Coupe 1974 911 Targa |
My 1976 911S is a non cat. Two year ago I just passed, after the smog I disconnect the smog pump and store it in the shelve. I have not been driving the car, Maybe 2500 mile over the pass two years. So I don't know what has changed. I will check out the smog pump. Do you know how much flow I should get out of the smog pump? CFM or Ft/Min at what RPM? Or is the car just setting to lone?
Ken
Fuchs w h o r e
Fuchs w h o r e
So what the the flow rate of an air pump for a my car?
![]() The top number is the latest my fail and the bottom is two years ago.
Fuchs w h o r e
First, retard your timing by 3º.
Notice how much lower your NOx is this time compared to last time? This indicates your engine wasn't warmed up as much as it was. Your previous test shows it was running rich even though it passed. A small adjustment may be warranted. Last edited by dvkk; 09-28-2008 at 01:39 PM.. |
Member 911 Anonymous
Hey, at first I thought you called him a RETARD, LOL.
I agree with warming her up enough prior to testing.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
You might have better luck setting it the way it was two years ago when it passed, before you got the LM-1/ aux box and played with the mixture.
Once I dial the in the mixture and record the data I will be able to setup the car in two years.
I passed!! After leaning how the used the LM-1, I was able the set the mixture so I will pass the smog test. I used AFR to %CO chart the set the mixture. Here is a link to the chart http://www.perfectpower.com/Technical_info/afr.asp
So I am back on the road legally.
disband
did you ask what the implications of a fail with the "gross polluter" tag? not to chicken litte you but i had a GP commuter car some years ago that because of that test i had to have the car smogged every year after that. i even got it passed after the original GP test but the state still dogged me. would be interested in hearing what you find, or worse discover when you open your registration next year.
i watch close because i do the ssi back to stock exhaust every two years now. i cringe every odd numbered spring year having to replumb the thing. the ssi's are worth every minute of it though.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
