I think you are doing a wonderful job - outstanding.
Jesper |
Fitted the 'parcel shelf', however its easily removeable using allen bolts. It makes up part of the removeable rear seat section.....should add abit of extra sound deadening.
![]() Will add another layer on the backside to clean it up abit... ![]() ![]() ![]() ![]() |
When I put my red car through its first UK MOT I needed to change the rear-light lenses. Whilst changing the lenses I tried to make the lights abit brighter by re-finishing the internal part of the unit. I thought about re-chroming, too expensive, spraying, too messy........baking foil and double side tape, perfect! I Updated these lights this afternoon. I would like to think it makes some difference...
Before... ![]() Foil on the flat and vertical surfaces... ![]() ![]() ![]() New lens in place, ready for final fitting... ![]() Thanks Chris |
Senior Member
Excellent idea on the foil and double sided tape! I have some fronts I need to work over and will try this on them!
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Are you going to put LEDS in there??
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Dave Hanning
More nice work Chris, way to go
1975 Carrera coupe 1974 Targa 1998 Boxster 1999 Boxster |
The other option was to use mirror card... ![]() ...only problems being A. did not have any to hand B. maybe an issue if any water gets in? Last edited by jury; 08-02-2010 at 12:00 AM.. |
Bird. It's the word...
Chris, great build - thoroughly enjoying it!
I thought I'd flag that the closed cell foam tape you're using for the bonnet doesn't have or create a channel to clear water... ask me how I know ![]() Cheers
John Forcier Current: 68L 2.0 Hotrod - build underway |
Hey Chris - a great build this. I've got it bookmarked!
You could try Douglas Valley Breakers in the UK for the engine mounts. You might need to persuade them to cut them from the car though. Failing that, there is a guy on ebay breaking a 2.7 911 - he might do it, although some of his prices are a bit unrealistic IMO |
Hi! What an awesome project! I like the seats as well, could you tell me where they're from? Bart
Dave Hanning
off and on Porsche has motor mounts in stock unless they have gone permanently NLA. Have you tried ordering new ones from Porsche?
make your own. I feel like the stock ones are flimsy anyways.
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
https://www.europaspares.com/SEATS/COBRA_SEATS/COBRA_SEAT___CLASSIC_RS___SIGNATURE_VINYL___CLASSR SIG01__5132.html But they are also available through Demon Tweeks in the UK |
![]() (May be over in Portland later in the year, will let you know) Cheers Chris |
chris - this is what I have;
Robert Williams 70' 911T |
Cheers, I had a look on their site:
https://www.europaspares.com/SEATS/COBRA_SEATS/COBRA_SEAT___CLASSIC_RS___SIGNATURE_VINYL___CLASSR SIG01__5132.html https://www.europaspares.com/SEATS/COBRA_SEATS/COBRA_SEAT___CLASSIC_RS___STANDARD_VINYL___CORD_49 18.html There seem to be two variants of the same seat... has anyone seen the two next to each other and is it worth forking out for the more expensive version?
'81 SC Targa - 16' Fuchs, Whale-tail |
I think (but I may be wrong) the expensive option just allows you to choose different colours? But its the same seat either way.....
Thanks Chris |
