83 CHECKER
How far beyond 7K have you been??
Spun it well beyond the old 6.2, then pushed it beyound 7K, stock 3.0 SC , only 29 K on the engine. I've turned it a good 7.5K and it asked for more??
'83 911SC CAB
'90 ZR-1
'68 TR-250
Old 12-09-2008, 03:51 PM
theiceman's Avatar
if it is stock wouldn't the rev limiter have kicked in ?
Old 12-09-2008, 03:53 PM
Just alittle bit more and wait for the explosion!!!!!!!!!!
Old 12-09-2008, 04:54 PM
MBruns for President
JeremyD's Avatar
Tachs are not always accurate.
Old 12-09-2008, 04:56 PM
Band.
I'll let you do it, thanks. When I pass you it means I just shifted.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-09-2008, 05:49 PM
Warren Hall Student
Bobboloo's Avatar
Considering it looses power after redline the question becomes... Why would you??
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 12-09-2008, 06:17 PM
iamchappy's Avatar
Stock valve springs were not engineered to perform at those thresholds. Your heading for an expensive lets see how far it will go. i occasionally ran mine up to 7 but really you shouldn't.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 12-09-2008, 06:51 PM
Czar of C.R.A.P.
dfink's Avatar
I'm guessing at somewhere around 11K to 12K.....
Once............
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 12-09-2008, 07:15 PM
probrobly has the eqivelent of 60k on it now
Old 12-09-2008, 07:33 PM
I have a red line set in the ECU of 8.2.....! but guess what it is built to handle it!
Old 12-09-2008, 07:36 PM
You won't do that for long without paying a very dear price,...
The consequences are utterly catastrophic and leave you with VERY few usable parts.
I'd keep it under 7K unless you spend some $$$$ to make it reliable.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-09-2008, 08:22 PM
Wer bremst verliert
JohnJL's Avatar
Note to self: Never buy a 1983 SC Red Cab from Saratoga.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-10-2008, 12:39 AM
Certainly when you hit the rev limiter it feels like it could could go on a whole lot higher in the rev band - but for power it is really just stupid. Sometimes on the track you could wish to go a little higher rpm's just to avoid shifting up just to shift down again, but that is the only time when I want more rpm's.
I read somewhere that as the earlier cars reved way past 7000, that the walve-train mechanism is built to handle that? But the bigger deplacement engines that followed really doesn't have the cams to give any power higher up the rev-band. And I guess that "if **** hits the fan" way past 7000 rpm's then you'd better get a new engine....!
If one build an engine like an RS/RSR then 7000 rpm's and more should be safe! So these engines have it in them... If I had the money....
Old 12-10-2008, 02:57 AM
abit off center
cgarr's Avatar
Around 8k in my 69 912, it was so smooooothe!
______________________
Craig
G2Performance
Old 12-10-2008, 03:16 AM
Wer bremst verliert
JohnJL's Avatar
Uh, what does that mean?
Old 12-10-2008, 03:45 AM
Az911's Avatar
Send a message via AIM to Az911
I'm guess he build the engine to handle higher then stock rpms
72T RS look
96 993
Old 12-10-2008, 03:48 AM
It means that I have a rev limit of 8.2k but the engine has all the bits to handle it.....! if I had a stock engine the rev limiter would also be stock!
As many have now pointed out it is a bit silly to push harder than the limit of the valve train.......unless it is a destructive testing excercise.
Mark........
Old 12-10-2008, 04:06 AM
IROC's Avatar
Before I really knew better (and before the internets were around) I replaced the stock rev limiting rotor in my '76 2.7 with a rotor from a '73 S (?). The new rotor had a allowed 7300 rpm IIRC. I used to use it. Especially coming out of turn 7 at Road Atlanta in 2nd - the extra rpms came in handy there and many other places.
My stock 2.7 routinely saw 7k+ rpms and never missed a beat. YMMV.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 12-10-2008, 04:27 AM
cycling has-been
bkreigsr's Avatar
my son took the 73 up to 7,500 - ONCE
Bill K
Old 12-10-2008, 05:33 AM
theiceman's Avatar
..funny.. that is EXACTLY what i was thinking
Old 12-10-2008, 06:03 AM
