pm sent to you Tony...
Thx again! Bob
I live for 911 tweaks... |
Bill is Dead.
My father builds custom cabinetry, so mine will end up in a very nice box at some point.
If others are interested, and if Tony does not offer something, I will take photos of whatever my father designs and will ask him to work up some quotes and options. This will of course have to be after the tool arrives so he can take measurements and design the box. By the way, what is the VW385 tool pictured on page one used for?
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
I have not see an example of VW385 in person, but I think it has a probe that attaches to the middle and some type of internal mechanism within the tool that redirects the in/out probe movement 90 deg then down the shaft to actuate the indicator that is mounted on the end of the shaft. Frankly I have to wonder if the P258 tool might be more accurate?? (less moving parts and potential for slop), but maybe a bit harder to use than VW385.
1972 Porsche 914 BlueSkyMotorsports.com |
Tony, I'll take one. Sent you a pm.
Keith Lally 85 911 Blue Coupe - gone 84 911 Silver Coupe - gone |
Schleprock
Tony,
Did you consider making the G50 spacer for the G50 side cover? I'll take one as it looks like my next car (racecar) will have a 915. So the G50 spacer is not a must for me. But it'd be great if you could produce a G50 spacer since i'm sure i'll need one for a friend (or me) in the future. Thanks for putting in the time and effort on this repro job! >Kevin
Kevin L '86 Carrera "Larry" |
Kevin,
I haven't spent to much time trying to figure out what to do with the G-50's I have one in the shop now with the gearbox apart I could take some measurments. I would suspect it would be easier to just get a G-50 diff and machine it to work.
Tony Proasi 1969S 1957 VW Pickup |
Guy's looks like the three ready to go are sold pending payment. These people have gotten a PM so you know who you are. I'm taking 100.00 deposit on the next three I would like to have that by check and I will not cash it till they are done and the remainder is paid. I have about 5 more diffs to use then I'll need to start finding some I have to have the diffs from a 65-69 sandcast aluminuim transmission so if anybody has any to offer I'm interested.
Thanks, Tony
check going out today Tony...many thanks again!!
Bob
PM sent (I will take one from the next batch)
Schleprock
Tony,
My $100 deposit is in the mail. Thanks a bunch!
The VW 385/1 is used to set pinion shaft depth. The 385 is much simpler to use than the mandrel set-up because installation and removal of the tapered diff bearings is not required. The 385 uses two pucks in place of the bearings, and those pucks simply slide onto the 385's shaft. Also, on the mandrel diff shims must be used under the bearings in some combo that will eliminate axial play. The 385 uses an internal mechanism to pull the pucks tight (eliminate axial play), so minimal set-up work is required prior to setting/adjusting pinion depth.
Keep the Shiny Side UP! Pete Z. |
Ok guys for the three guy's that paid for the tools they will be going out on friday I had a quality control issue with the block when they were milled they "sprung" and were causing inconsistent readings the have be redone in cold rolled steel and will keep there shape. I apologize for the delay.
Thanks, Tony
thx for the update Tony... I await with full confidence and look fwd to receiving!!
Bob
Bill is Dead.
No problem.
I appreciate your quality control effort.
No rush Tony. Thanks.
So, did this ever see fruition?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Schleprock
I sent a deposit. Never got a follow-up, despite a few asks, regarding when the next batch of tools would be produced.
Guys I will not be making anymore of these it turned out to b a lot of time and work that I can't dedicate to the project. Kevin I sent you a PM
Schleprock
PM rec'd and responded. Tony pointed out that my deposit (check) was never actually cashed. Mistake on my part in my check register, clearing it when it actually hadn't been cashed. So we're all square.
Sorry to see the tool won't be produced any more. I completely understand things like these take a lot of time, w/out much benefit ($). Nonetheless the effort and willingness to provide a tool that helps the DIY'ers is very gracious.
I've got one of these that was never used. $500 shipped in conus if anyone is interested.
