Band.
The thermotime switch did have a wire hooked up to it, that it zip-tied onto the harness and (IIRC) went up to the CSV behind the intake boot.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Intersting. I wonder iof some one wired the thermo time switch to activate the cold start valve. This is not stock. you can check the 1973.5 diagrams here to verify. In my car, you pull the hand throttle up all the way to start. When you do this, two things happen: You get a very high starting rpm; and it closes a microswitch that provides power to the cold start valve. Power is only on the microswitch when you crank the engine as the power source is the same one that tells the starter motor to crank.
Happiest when Tinkering
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
EMT/TechRescue Instructor
Cant wait to see it all clean and powdercoated!!
Band.
Wow
![]() ![]() I'm soooooo glad I took this out. Probably about 2-3 pounds of gooky, oily dirt up behind that sucker. It's gonna be a looker when it comes back, I hope! ![]() ![]() Here's the real reason: See that grey-black oily booger? That's about 1/4 of the stuff I dug out with my finger when I took off the nut next to the drain plug. Thanks for the glove, Bill. ![]() ![]()
'82 SC TL
Wow! I can hardly wait to see how it's going to look all cleaned/painted/prepped up!! Keep up the work,good luck.
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Gogar, nice work!
Don't feel bad about not pre-cleaning the engine before you removed it. I purposely left the engine on my cab untouched because I wanted to take my time and suss out where exactly all of the oil leaks were coming from once I had my engine on the stand. It's a good opportunity to learn things. It's amazing the amount of grease, grime and dirt that you will have removed from the engine and engine bay when you're done. Pounds, I would estimate. It's the little things: One of the most rewarding parts of my rebuild was after I refitted the cam towers and heads, and installed new oil return tubes. That's when I realized, holy crap, this thing's coming together! Have fun. ![]() Brian
'82 SC Targa '83 SC Cabriolet |
Band.
Everything else? Oh yeah, EVERYTHING else was leaking.
Friend of Warren
Years ago on my 72E I had similar oil return tubes. I couldn't find replacement o-rings so I went with the steel collapsible.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Let me know when you are ready to reinstall it..
Bill |
Band.
Here's something weird kind of.
There's this bolt that's on the Driver's side of the case, down low, about the same height as the intermediate shaft. It's got JB weld smeared all over it.
What is that bolt? I assume the JB is there to stop a leak because (I'm also assuming) you can't back that bolt out of the case . . . . . Anyone? ![]() Alright! Looking better. I think I'm about done trying to clean this thing off. ![]() I sat there and turned the pulley and listened to it go "poof, poof, poof" for a while. That was fun. It's the little things, you know.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 01-08-2009 at 03:46 PM.. |
There is no bolt there I believe so I would think it would not or might be (depending on the way you think) a good idea to take it out.
Band.
Oh yeah there is one in there.
No I mean there's not supposed to be a bolt there. And if there is supossed to be a bolt there it wouldn't be at that odd angle.
Your engine's looking good!
Why is it in your engine pic that, when looking at the right bank of cylinders, No. 4 looks different height-wise to 5 and 6? Brian
Band.
I think it's just the angle of the pic. My driveway/alley is a slight downhill.
Band.
Lke . . . . Christmas, man.
Oh yeah.
![]() Didn't want to unwrap everything, but you get the picture: ![]() Not BLING, more like bling, I think. I like it. ![]() I had the edges of the fan blades taped off, and my powder-paint guy said the paint would only add about 2 mils to the fan housing, and there's no clearance problems at all. I'm very excited about that. And YES, I have made provisions for not having paint on the surfaces the fan belt touches. No worries! ![]() OOOOH - Ceramic! Inside and out! ![]() One of you guys had your HE's at this place the same time I did - they'd never seen them before, and then they got two sets in a week. http://appliedplastic.com/ And, just as much fun, but in a different way: ![]() ![]()
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 01-13-2009 at 03:35 PM.. |
Nice sock! Gold toe?
The parts look nice too!
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Powder coating on fan
You may have to file off some of the fan blade ends so it fits properly. How many mls. of powder did they apply ??
Band.
