jyl jyl is online now
jyl's Avatar
Next question - how are you guys mounting, holding or positioning the iPhone during the test? Will a jury-rigged arrangement such as rubber-banding the iPhone to the sunvisor work?
Old 03-25-2009, 06:28 PM
mechanic by night
You guys are going to make eveybody want to buy one of these things, including me.
76 911 "The Blond B_ch"
(what the wife calls it)
09 Mazda 3
06 subaru legacy spec B
91 track miata
Old 03-27-2009, 06:50 AM
rlh930's Avatar
How are you guys mounting the iPhone?
I'm using something called a "ProClip" (http://www.proclipusa.com). I'm mainly using it because it also allows connecting the iPhone to the car audio, and can be adjusted for good visibility when I'm using Google Maps. Really, though, for dyno use, anything that holds the iPhone steady in the proper position (center of car, screen perpendicular to direction of travel) should be fine.
Roger
'87 930
'73 911T
Old 03-27-2009, 07:54 AM
jonbot's Avatar
You are correct sir, and this makes the most sense. Why else would it be reading 70MPH from just tilting it in my hand?
Originally Posted by rpollock View Post
I don't think the ipod touch has gps. The accelerometers are used to calculate speed.
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 03-27-2009, 10:19 AM
slodave's Avatar
Originally Posted by 84CarreraSC View Post
Your results are pretty close to my dyno results with a similar setup.
What gear was the car in?
Old 03-27-2009, 10:47 PM
slodave's Avatar
I had mine lying on the passenger seat, secured enough so it would not slide around.
I did 6 runs and that was plenty. I really don't need to tear my tranny apart right now.
If the app is updated with major improvements or I change my car, I'd make a couple more runs..
Old 03-27-2009, 10:54 PM
fat cab's Avatar
do they have an app for the track? for like lap times and G's thru turns?Not to interested in straight line info..
Old 03-28-2009, 05:00 AM
Free minder
Aurel's Avatar
Yes they do!
http://www.tomatounion.com/index.html
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 03-28-2009, 05:19 AM
Free minder
Aurel's Avatar
From their website Q&A:
Q: What is the best way to mount the iPhone when testing?
A: Mounting is a concern for accurate results. Unfortunately, mounting is very vehicle-dependent. On some cars, a cupholder is fine, as long as the iPhone is wedged pretty well and does not move around. For in-house testing, we have a cradle which mounts to the windshield with suction cups. This took a bit of custom work to set up, but does the job nicely. Any off-the-shelf cradle which fits the iPhone should work, as long as it holds the iPhone facing the front of the car, and does not bounce around.
Old 03-28-2009, 05:35 AM
anyone know if this works for similar phones? Not iphones?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-28-2009, 05:45 AM
Free minder
Aurel's Avatar
Q: Will you make Dynolicious for [insert your platform here]
A: At this time, we are porting Dynolicious to the Blackberry Storm. We currently do not have plans to support any other platform. The best way to convince us to port Dynolicious to something else is to visit our forum and show your support.
Old 03-28-2009, 05:53 AM
t951's Avatar
Not a good run
You can see a lot of hesitation during the run, and the fact that I take my time to shift the 915.
I also had 525lbs of human in the car. (My passenger with the iphone weighs at least 300).
We also guessed on the weight of the car, with us.
tk
08 911 C2S - Sold
13 Audi A4
14 Jeep SRT 500HP
Old 03-28-2009, 08:25 AM
Free minder
Aurel's Avatar
If your passenger was holding the i-phone, that would explain the non-smooth curve.
Old 03-28-2009, 08:31 AM
t951's Avatar
I believe he was.
tk
08 911 C2S - Sold
13 Audi A4
14 Jeep SRT 500HP
Old 03-28-2009, 08:37 AM
Free minder
Aurel's Avatar
I am about to get one of these; I am just wondering if the arm is long enough with the dashboard over the lighter plug...
http://www.hdaccessory.com/servlet/the-1055/Apple-iPhone-iPod-Touch/Detail
Old 03-28-2009, 08:44 AM
jyl's Avatar
I didn't have the best luck with FM transmitters when I was using my iPod in the 911. I ended up using a wired connection.
That said, the device you linked to is inexpensive enough that there's no reason not to try it.
Old 03-28-2009, 09:28 AM
4th
Old 03-28-2009, 09:56 AM
Sorry what forum? Iam not sure if my Delve would work or not for this but would be interested if so
Ben
89 944,85.5 944
914-6werkshop.com
Old 03-28-2009, 11:47 AM
Free minder
Aurel's Avatar
http://www.dynolicious.com/support.php
http://www.bunsentech.com/forum/viewforum.php?f=4
Old 03-28-2009, 12:07 PM
theclaw's Avatar
I just installed PocketDyno on my iPhone before realizing that Dynolicious was a different app. Has anybody compared them? I installed the $12.99 version of Pocketdyno. I like the graphics on Dynolicious.
Now all I have to do is find a stretch of road to try it out on.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 04-12-2009, 01:33 PM
