where is your msd box?
Hey guys. Im installing the msd ignition box setup and Im not sure where or how to mount it. I took the cd box out and the msd box is like twice the size of the cd box. SHould I just drill into the metal bracket? Should the wiring harness be on top or bottom of the box? Id love to see some pics..
Thanks in advance and Happy New Year!
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
mine is in the stock position...wire harness faces down. i am at work, so if nobody else posts up a pic, i can get you one tonight.
poof! gone |
were you able to mount all 4 bolts? Also what do I do with the old plug? Do I just stash them away somewhere?
yea, i mounted all four corners. those rubber threaded bumper things are really nice. makes taking things on and off really easy.
poof! gone |
I have the MSD box 6AL. Its alot bigger and there is no way it will mount onto the bracket.
i have the 6AL also. i guess i have to post up some pics later.
poof! gone |
please do. Thanks so much. Does anyone else have pics? A search for MSD doesnt work.
hahaha. called my wife to see if she could snap a pic..i could feel her eyes rolling over the phone.
i will get them tonight.
poof! gone |
haha, sorry if you get a bad tv dinner tonight Vash
Does the regulator mounted next to the cd box have to be trashed also?
ok, next question. Where did you install your power wires? DO I have to go under the car to locate the starter cable?
Here's a picture of my installation. The MSD box is larger than the stock CD box, but it can be mounted in the same location. The upper forward corner hits the wheel well, but if you space it out just 3/4 of an inch, it will clear. Vash used rubber spacers, I just used a 3/4 inch hunk of plywood painted black. It has held up just fine for about 10 years.
![]() I got power from the top engine compartment fuse as shown. Since this picture, I have run the wire behind the electrical panel for a cleaner installation.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 01-02-2009 at 01:31 PM.. |
Thanks Walter. I was able to mount the box sideways. I removed the regulator. I'm pretty sure I have the alternater with the built in regulator. Atleast Im crossing my fingers. Now as for the power wire, the book says it has to be a constant hot wire. None of those fuses are constant hot. Does it matter if its constant hot or not?
Hope this helps...
got this from a fellow pelican...wanted to pay it forward.
1990 BMW 325is 1977 Porsche 911s 1979 Alfa Romeo Spider 1999 Lexus LS400 1978 Porsche 911 SC 258,000 miles and barely run in! |
I mounted mine where it would get max air flow. A good place is in front of the engine. MSDs get hot.
not my setup
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Mack6820,
If none of the engine compartment fuses are hot, I'd go for the starter next.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Thats a nice setup Ronin but I dont have carbs. I have the spaghetti of a CIS.
Not a street solution, but on my race car, I mounted it on the other side (inside) of the firewall from where Ronnin has it. I wanted to keep the electronics away from the heat. Works great for me.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
some guys around here add a section to the electric panel that extends it so it'll mount the MSD. It's not hidden behind the panel cover. I built a seperate panel that sits between the electric panel and front cabin bulkhead, but I don't think you'll have room for that? I'd try to find a pic of the MSD mounted on the extended elec panel so the box is able to see some cooling.
now my pain is to figure out how to route the power wire to the starter.
