It would be extremely hard to go along the wire harness and the starter wire unless you remove the CIS. You can see on the picture belowwhere the wires go through to the starter.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Here is how my box is mounted with one screw and a plastic wire clamp
ok guys. IM finally done. NOW the car wont start! I checked all the connections. Im getting power to the box and the ground is good. geez! any ideas?
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Msd
Here is mine - Fabricated an .080" aluminum "platform" for it to fasten to. EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Do you have power to the coil? Are you getting spark?
Im not getting any spark. When am I supposed to get power to the coil? How do I check it? I checked the power wire on the coil as my neighbor turned the engine over. I got nothing.
How did you connect the MSD to the old wiring? I simply connected in to the 6 original plug. The purple and green wires (if I'm remembering correctly) connect to the "green wire" to the distributor.
Look in this thread MSD magnetic pick up for info on connecting, I have an image of how I connected the msd. (Provided by Fred Cook, you can search his name for info on his setup.) Jay
2002 Boxster Speed Yellow Last edited by jtfreels; 01-02-2009 at 03:36 PM.. |
I thought the purple and green wires dont get used? I dont have points.
On my set up the purple and green wire go to the "green wire" "pig tail" on the distributer as stated by Jay.
Jay your link to your thread didn't show up could you post it?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 01-02-2009 at 03:46 PM.. Reason: Jay not Jah |
MSD Mounting Location
My SC has an internal regulator alternator, so I simply rotated the rear window defrost relay 90 degrees and mounted the MSD box horizontally.
It fits under the electrical panel cover (almost) so that all you see is a small amount of red. I ran the ground wire to the mounting bracket and to the engine to make certain that I had a complete ground. Good luck with your project!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Edited the post with the link which is
MSD magnetic pick up Jay ( not Jah!, can't even get my own name straight at time )
2002 Boxster Speed Yellow |
Thanks Jay!
So the green and purple wires go to the distributer green wire which is a has an outer sheild. The green wire connects to the sheild The purple wire goes to the green wire
well I re-ran the green and purple wires and then the coil wires iaw the diagram by Fred Cook. She still wont start. I think the green and purple wires are only for earlier cars with points. But I wired it anyway.
I'm still not getting spark at the plugs. I think tomorrow Im gonna rehook up the old cd box and see what happens. Thanks for the inputs guys. More to follow tomorrow.
The Purple and Green wire are for the magnetic pickup which replaces the points that were on older cars. The pickup tells the box when to send spark where as in older cars the points did this.
The SC Distributer has a magnetic pick up that is detected and transmitted via the green wire. Best of luck, Shane
Try reversing the purple and green wires;
The green wire connects to the shield The purple wire goes to the green wire It seems a lot of people get this wrong. It wont hurt anything, try changing them from whatever current configuration you have.
MSD mounting
Here's mine. I made an aluminum plate that bolts to the stock mounting holes and then used rubber, threaded spacers to mount the MSD to the plate.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I removed the sound insulating pad off of the firewall and made a carbon fiber sheet to hold my voltage regulator and MSD box. I can take pictures if you want
Whiskyb 69 911 Wasaga Beach |
AutoBahned
yes, please - pics of the CF sheet and msd box...
<insert witty title here>
I mounted mine in a similar location to the picture RoninLB posted, but about inches to the left. I just screwed right into the firewall, and it's held no problem, even through track days.
Sorry can't help with the wiring - I can't remember at all, and my car's away for storage. I do remember having to just keep trying one or 2 connections until I got them to work.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
i'm back. mine is mounted like al's.
i used the purple and black. the PO snipped the factory harness out and wired the MSD permanently. it should be easy to go back. run the power wire to the starter. if you look, you can see where the large AC hoses go. follow them down and you will be right next to the starter. i used an inline fuse for added peace of mind. i cannot remember the amps. our cars need the purple/black trigger wire. no sparky without it.
poof! gone |
