Longer stud question
I need longer studs (its not funny guys). I have front disassembled but not rear.
A few questions:
1. A good source to purchase
2. How to install in hub ( or should I have shop do it)
3. What must be done to rear to get to hub for installation
TOT
TOT
Old 01-17-2009, 01:03 AM
Studs
ANy help ?
TOT
Old 01-17-2009, 06:18 AM
Are you asking how to install the new studs into the hub? The studs can be easily pulled into the hub. Just line up a stud in the hub, put a bunch of washers on it, and screw one of the lug nuts onto it. You'll be amazed at how easily it pulls itself into the hub.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 01-17-2009, 07:02 AM
A few questions:
TOT
They are sold right here! You might need to type ' wheel studs' into the search and there they are.
Tony G
2000 Boxster S
Old 01-17-2009, 08:20 AM
Somatic Negative Optimist
Gunter's Avatar
Cool
ANy help ?
It's a bit of work but doable.
Rear has to be dismantled similar to the front to get to the studs.
The rear hub requires more effort because of the large nut which has an enormous torque on it.
Edit: Later replies say the rear can be done without removing the hub.
What year/type 911 do you have?
I suggest you get a Bentley Repair Manual.
Place the hub on a heavy steel base studs facing up, spray a little penetrating oil on the old studs, knock the old studs out by using a 4lb hammer.
If you want to save the old studs, use a piece of Alu or brass, hammer away.
Install new studs as suggested above.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-17-2009, 08:42 AM
I have replaced the rears w/o removing the hub. You need to remove the e-brake adjuster and rotate the hub for each stud but you can bang them out one at a time. Replacing them is a bit different than the fronts, which you can just hammer in. I made up a spacer and a washer and used a steel wheel nut and basically sucked it up into place. The word of caution here is that you will need to torque the wheel and retorque after driving a couple miles. Checking rear wheel torque a few times is prudent to ensure the stud is fully in the hub.
Tony G
2000 Boxster S
Old 01-17-2009, 09:51 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 on not removing the hub. But you need to raise both wheels at the rear. I did not so I had to dis-assemble the e-brake to get at the wheel studs. You will need to re-adjust the e-brake when down. Just make good notes on removal and assembly. The spring is quite fussy.
I had an old lug nut that I cut the end off too make a open ended lug to torque down the new studs.
'85 Carrera Targa
PCA/POC
Old 01-17-2009, 10:23 AM
Studs
Thanks all for the input. TOT
TOT
Old 01-17-2009, 07:19 PM
grateful user
don gilbert's Avatar
DO NOT buy studs at the auto zone, they have longer ones that fit our cars but are junk. i striped out 3 tourqing by hand, napa sells belknap studs, you cant get anything better than that without going to an alll out race stud, wihich cost about 15 bucks apiece.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 01-18-2009, 05:30 AM
Studs
Good ...appreciate it . TOT
TOT
Old 01-18-2009, 08:23 AM
