clutch disk width
Hi,
I'm going to put new cover on clutch disk - 2.2 engine 901 gearbox.
Maybe somebody knows what is the width of the new one - i.e. one side?
thanks
Marcin
1976 3.0 Carrera sold
1975 2.7 backdated to 73' RS
1971 2.2 T Targa
Old 01-23-2009, 06:30 AM
Grady Clay's Avatar
Marcin,
The clutch disc is a 225 mm diameter (same as ’72-’86) and uses a ‘pull-type’ clutch pressure plate but is unique to the '70-'71 2.2. The significant difference is the splines in the clutch disc hub mates with the transmission input shaft of the type 911 (not type 901) transmission. These splines are common to ’71 and all earlier Porsche and even pre-war VW. The clutch actuation parts of the type 911 transmission are necessary for the pull-type clutch.
I don’t understand your question:
Are you asking about the thickness of the disc friction material?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-23-2009, 06:44 AM
Sorry for misunderstanding.
I'm asking about thickness of the disc friction material!
1971 2.2 T Targa
Old 01-23-2009, 06:46 AM
Grady Clay's Avatar
Marcin,
Replacing the Porsche clutch disc friction material is not common but is probably possible. There are businesses that specialize in this. Typically, they have the specifications for every clutch ever made in the world. Porsche does not publish those specifications in their normal technical information that I have ever seen. You might find that info on the Sachs site.
Our host sells the new OEM part at a good price.
Best,
Grady
Old 01-23-2009, 06:53 AM
I have the guy doing it in one hour for 30$ but he doesn't know the thickness.
I will check Sachs page.
1971 2.2 T Targa
Old 01-23-2009, 06:59 AM
Grady Clay's Avatar
Marcin,
Be sure he doesn’t remove the spring system between the two friction pieces. If so you will have an incredible ‘judder’ on start-off.
Please post the numbers and your source after you confirm the repair works correctly.
Where are you located?
I assume you have a spring center for the hub and not a rubber center clutch. The rubber is prone to failure. (Yes, there were OEM rubber-center 2.2 clutches.)
Best,
Grady
Old 01-23-2009, 07:21 AM
He doesn't remove the springs and it has a spring center.
I'm located in Poland so pretty away. I have used this specialist before . He made special sport disc for my friend's Alfa Romeo GTV and it was fine.
1971 2.2 T Targa
Old 01-23-2009, 07:30 AM
