3rd_gear_Ted's Avatar
CIS & Cat Bypass
Are there any reasons a CIS motor can't deal with a cat bypass? I would like to install one to eliminate the heat a cat converter causes.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 02-04-2009, 07:10 PM
SteveinTO's Avatar
That's what I did on my '82. Works great. Make sure you get one with a bung for the O2 sensor if you have one. You may want to tweak the A/F afterwards as mine seemed to do more popping & farting on decel. It may make just a bit more noise, but not much. Hard to tell.
Old 02-04-2009, 10:45 PM
AzTarga's Avatar
Did it on my '81 . Works fine , sounds great .
81 911SC Targa 3.0
Old 02-05-2009, 08:33 AM
joe payne's Avatar
No problems and gives the stock muffler a nice throaty sound.
jtp911
Old 02-05-2009, 08:55 AM
you see Arthur...
jasonlee's Avatar
cat bypass on my 82 SC with CIS. No issues at all. a little popping on decel, but sounds cool
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-05-2009, 09:14 AM
What the ?
glewis80SC's Avatar
No issues on my 80SC, +1 on the 02 sensor hole.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 02-05-2009, 09:34 AM
Thanks gang, Just wanted to be sure those CIS hybrid circuits from the 80's have the ability to deal with the change. It appears that all the CIS controlling is done up front on the intake side with pressure sensing & flow rate control.
2016 Cayman S
Old 02-06-2009, 04:43 PM
Peter Zimmermann's Avatar
Be aware that in CA your car will not pass smog with the bypass on the car. It will probably pass the visual, but the cat is needed for the tailpipe test.
Keep the Shiny Side UP!
Pete Z.
Old 02-06-2009, 04:48 PM
RETIRED
Joe Bob's Avatar
Typically a 3.0 can pass with SSI heat exchangers. At least mine did when I convinced the guy they were dual cats.....
2012 ML350 3.0 Turbo Diesel
Old 02-06-2009, 07:19 PM
Your right about putting the Cat Converter back in there for smog testing in CA. Thats where the anti-seize on all the bolts comes into play.
2016 Cayman S
Old 02-06-2009, 07:53 PM
