Matt - very nice installation. I really like the stock location. There have been a lot of threads on where to install the MSD unit, and I think the stock location gives it a more professional look. After all, that's where I installed mine. I was also able to install mine without cutting or altering the stock wiring in any way. This allows me to go back to the original any time I want.
Tom F2 - look again at the picture of the install, the tach adapter is clearly marked in the lower left of the picture.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 12-13-2009, 05:53 AM
Originally Posted by Tom F2 View Post
What is not clear, to me, is where folks have mounted it, when needed.
many electrics should be kept as cool as possible, especially the CD box.
look as various installs and do what's good for you
different strokes......
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-13-2009, 06:05 AM
Now I'm getting it...
Fest 911's Avatar
Fest 911, your guide is very well done. Thank you.
I do not understand your answer about the tach adapter. Did you need it and, if so, where did you mount it?
FWIW, I think that the answer on the need for a tach adapter can be found here: MSD Users - What brand of tachometer do you have?.
Tom
Tom,
My tach needed the adapter. If you look at my before and after pics at the beginning of this thread you can see that I mounted the tach adapter in the fuse/relay panel in the engine compartment.
As far as need is concerned, I spoke to a technician at MSD (before the install) who informed me that some Porsche tachs require the adapter and some don't. I tried mine without the adapter and the tach wouldn't work. I installed the adapter and the tach came to life.
Walter,
Thank you for the feedback!
Matt
The best labor saving device for today is...tomorrow.
Old 12-13-2009, 04:02 PM
brads911sc's Avatar
Sounds like you need a new mechanic. Seriously if you dont want MSD, you can get your Bosch unit rebuilt for less than the price of a permatune... Permatune has a reputation of being the least reliable. Took me 2 hours to install my MSD. Not sure who wouldnt have the ability to do it...
From our host:
Bosch CD Unit, Rebuilt, 911 (1969-77) ** $250 core charge applies -- must provide rebuildable Bosch core in advance ** [More Info]
$350.00
10-8540-600-M46 Perma-Tune CD System, 3-pin, 911 (1969-77) [More Info]
$493.50
MS-6200 MSD-6200 CD System, 911 All [More Info]
$199.95
Not sure why anyone would go Permatune...
Originally Posted by 72T View Post
For those with less skill, you can get a Perma-tune unit that simply plugs in, and mounts at the same points as the stock CDI unit. No extra wiring, etc, required. As my original CDI recently went bad, I made the switch, and the new unit seems just fine. My mechanic, who vintage races early 911's, highly recomended it, and says he's never had a failure. About $400 or so. I do miss the whistle a bit, though...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 12-13-2009, 05:12 PM
cfries's Avatar
Great thread! Made this Permatune to MSD very easy.
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 03-07-2010, 03:42 PM
Fest 911's Avatar
cfries, Nice work! Thanks for posting the pic of your finished installation. After the install, did you notice any difference between the Permatune and the MSD?
Old 04-08-2010, 07:18 PM
MBruns for President
JeremyD's Avatar
clean install there cfries
Old 04-08-2010, 07:35 PM
www.waytekwire.com make some double wall shrink wrap that's tough and almost looks stock. I used a piece today to shield the 930 rear brake caliper fluid line that's very visible.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-08-2010, 10:15 PM
double shrink tube from elect spoiler motor
a nice application
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-08-2010, 10:34 PM
cfries's Avatar
Thanks guys!. I did notice a difference. It idles much better now and more responsive. Exactly what MSD claims. Haven't had a chance to drive it much, so I can comment on fuel mileage just yet.
61 VW Karmann Ghia
63 European Bug
75 911 Targa
Old 04-09-2010, 06:59 AM
