M491 - What was first year (other than RSR)?
I was curious about a car that the owner claims to have the M491 option. The car is a 1977 carrera. I know that the option was available 1984-1989. Was it available as a "quiet" option in the 70's?
......just curious James |
MBruns for President
1973 - the Carrera was the M491 option if my memory is still working
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Recreational User
Jeremy, I think you're thinking of the M471 - lightweight version of the RS. M472 was touring version, M491 was RSR.
Since then, M491 means factory turbo-look. As far as I know, that was first offered for the U.S. 84 model year. Unless this car was specially fitted this way from the factory in '77, I'd say it was an aftermarket conversion. There's certainly no shortage of those! Last edited by porschenut; 02-16-2009 at 06:40 PM.. |
Mike and Paula
per this web site http://www.turbo-look.de/e/1e.php the M491 was first introduced in 1984
Certificate of authenticity would tell you and he should have if real...money could buy just about any option, although it might have a different code. Sounds rather early.
1988 Carrera Coupe |
You are right - brain fart - it sucks getting old
IIRC, , boxsterGT a poster here, said he has a turbo look midyear 911 with it noted on the coa. I would send him an email and ask about it.
75 911s 86 951 sold to make room for baby seat 09 335i 6MT NVH |
Besides, in thoses days you could order whatever you wanted that your bank account could allow!
RGruppe #180 So many cars.. so little time!! |
So.......his 77 "could" be a wide body car? If he has certification, it could be inaccurate. How else can it be proved?
James |
Recreational User
The first year for M491 was '84. If you are lucky enough, or at least that's what the dealer said, to have the original hood with the sticker on it the option would be there. Another way is to check the brake calipers and see how they are mounted. The M491, as well as the turbo, had Brembo 4 piston calipers and on the back were mounted on the rear of the rotor. The suspension, except for the tie rod ends, was from the Turbo.
I have been told by many that when conversions were done it was way too much work to change the trailing arms and calipers for most. If the rear suspension has been changed on a conversion than some one did a very thorough job.
John Birkett 2008 Cayman S, Midnight Blue Metallic 84' Factory Turbo Look M-491 (gone but not forgoten) 02' Boxster S, Seal Gray Tiptronic (gone) |
