jamesjedi's Avatar
M491 - What was first year (other than RSR)?
I was curious about a car that the owner claims to have the M491 option. The car is a 1977 carrera. I know that the option was available 1984-1989. Was it available as a "quiet" option in the 70's?
......just curious
James
Old 02-16-2009, 05:11 PM
MBruns for President
JeremyD's Avatar
1973 - the Carrera was the M491 option if my memory is still working
Old 02-16-2009, 06:24 PM
Recreational User
porschenut's Avatar
Jeremy, I think you're thinking of the M471 - lightweight version of the RS. M472 was touring version, M491 was RSR.
Since then, M491 means factory turbo-look. As far as I know, that was first offered for the U.S. 84 model year. Unless this car was specially fitted this way from the factory in '77, I'd say it was an aftermarket conversion. There's certainly no shortage of those!
Old 02-16-2009, 06:37 PM
Mike and Paula
84 911 WideBody's Avatar
per this web site http://www.turbo-look.de/e/1e.php the M491 was first introduced in 1984
Old 02-16-2009, 06:46 PM
m110's Avatar
Certificate of authenticity would tell you and he should have if real...money could buy just about any option, although it might have a different code. Sounds rather early.
1988 Carrera Coupe
Old 02-16-2009, 06:53 PM
JeremyD's Avatar
You are right - brain fart - it sucks getting old
Old 02-16-2009, 07:00 PM
peon77's Avatar
IIRC, , boxsterGT a poster here, said he has a turbo look midyear 911 with it noted on the coa. I would send him an email and ask about it.
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 02-17-2009, 01:24 PM
onboost's Avatar
With some of the earlier cars, the Certificate of authenticity is sometimes incorrect or incomplete in its data.
Besides, in thoses days you could order whatever you wanted that your bank account could allow!
RGruppe #180
Old 02-17-2009, 01:38 PM
jamesjedi's Avatar
So.......his 77 "could" be a wide body car? If he has certification, it could be inaccurate. How else can it be proved?
James
Old 02-17-2009, 04:28 PM
Recreational User
porschenut's Avatar
Or falsified.
Old 02-17-2009, 04:39 PM
The first year for M491 was '84. If you are lucky enough, or at least that's what the dealer said, to have the original hood with the sticker on it the option would be there. Another way is to check the brake calipers and see how they are mounted. The M491, as well as the turbo, had Brembo 4 piston calipers and on the back were mounted on the rear of the rotor. The suspension, except for the tie rod ends, was from the Turbo.
I have been told by many that when conversions were done it was way too much work to change the trailing arms and calipers for most. If the rear suspension has been changed on a conversion than some one did a very thorough job.
John Birkett
2008 Cayman S, Midnight Blue Metallic
84' Factory Turbo Look M-491 (gone but not forgoten)
02' Boxster S, Seal Gray Tiptronic (gone)
Old 02-22-2009, 04:04 PM
