The engine doesn't want to go in! (engine install)
Ok, I suppose this is the time where I admit either (a) I'm stupid, or (b) that the Porsche is stupid. So I need some help since the Porsche doesn't response to my explicit shouts at her.
I took out the 2.7 that was in my 1976 and am putting in a 1981 3.0L. Did all the prep work and this weekend was suppose to be the weekend where the engine went in and the car came back to life. Well, not quite so. I jacked the car up the 30+ inches required to get the engine under, and then tried a number of things. (1) Jacking the engine up to meet the transmission (2) Lowering the car to meet the engine lowered on the ATV jack (3) Raising and lowering the transmission to try to hit that sweetspot None of these (and combinations thereof) worked. The fan either would not clear the lip on the back or the starter bolt was too long. I was about an inch off, at best! Please help. Is there a certain height that the car should be? The transmission should be? The engine should be? . . . where the engine and transmission MAGICALLY align? Or do I need to summon the porsche gods through some ancient beer drinking ritual and try again? Again, please help. |
If the car is at a angle cause of the rear being jacked in the air.
Try raising the front of the car to level it out a bit. Then for every inch you move the motor back, jack the engine up 1/2 inch until everything meets up!
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
I always drop engine/tranny together separate on the ground, put back together on ground then re-install together, I know this might not seem to help right now but it may be an alternative to your current frustration.
I will try the "jacking up the front of the car" bit tonight. And then I'll try the engine/tranny part, if the first try doesn't work.
But I still don't see how jacking up the front of the car will help me gain clearance for the fan. It seems like for every inch I gain of clearance for the starter bolt I lose twice as much of clearance for the fan. |
resident samsquamch
Sorry to hear of your frustrations
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Is the clutch fork engaged properly when mating the tranny?
I found this whole operation (solo) difficult enough with the engine and tranny out of the car. I can imagine it would be very frustrating to attempt to mate them with the tranny still in the car without a lift and good engine jack.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 02-17-2009 at 10:35 AM.. |
Your engine/tranny is connected prior to installing correct?
Just installed my motor last weekend...high level view was Get motor cleared and into engine bay Lift motor high enough to get the tranny mount bolts started (not tightened yet) Jack front of car to level out a bit Jack engine high enough to get rear motor mount bolts started. If the tranny bolts are in, there is no reason the rest of the engine should not align in the back? I mean you may have to nudge it left/right but certainly the fan shroud should not be hitting the rear crossmember?
A Thought
I really didn't want to take the fan off, but has anyone done this to make it fit?
Or, obviously it sounds like a lot of guys have other suggestions. I'm open to anything. So keep 'em coming. |
UNDER CONSTRUCTION!
have you disconnected the shift coupler inside the car to allow the tranny to drop far enough.i install these motors by myself and have never removed fan to install. you have missed a step on removal of the 2.7?
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
1980 911 SC
Try lowering the tranny with a smaller jack of its own. this should put the tranny at an angle sloping down towards the rear of the car.
Tilting the front of the engine up with a second jack should aligne the thru bolts enough to get them slid on there a bit . then just raise the engine more (As tho you were pushing it on an uphill slope) and it should all slide together. there isnt enough space to mate the engine and tranny while they are both level to the ground. The engine needs to go up at a slight angle Ive dropped the engine both ways, without the tranny attached is quicker it just takes a little more finese. My engine literaly sits on the arm of the floor jack and goes up at the same angle as the arm and i can still push it forward using the jack. Good luck and take it slow and easy. If all else fails I'm with the others on removing tranny and then attaching for the install.
Life's a Beach |
Yes, engine was connected to tranny prior to installing (the old 2.7 motor). Yes, the fan shroud does hit the rear crossmember. Ed, yes I disconnected the coupler. It's the issue of having enough room on both sides (tranny side and fan shroud side). |
UNDER CONSTRUCTION!
the only thing i can think of is that your tranny mounts are not allowing tranny to drop far enough or they are worn and the tranny is shifted to rear of car.
i let tranny hang as far down as it will go and block it up so shift rod isnt holding the wieght. and guis it all to gather from lowest point possible, ijust did this same change in a 75 2.7 out 78 3.0 in. theres not alot of room to play with but an inch is a foot when installing a 911 motor. ed
can the transmission be moved back without taking it off or redoing the mounts? any thoughts? |
UNDER CONSTRUCTION!
im not really sure on the mounts or moving the tranny while in car. but im thinking you had motor wieght from the 2.7 to pull tranny down a bit further to allow it to slide back while clearing rear crossmember.
maybe you have sport mounts and they simply wont allow tranny to drop down without help. look inside car with tranny hanging free and see how your shift rod looks it should be at the top of the hole in chassis, if not this is why you arent clearing, you may have to remove tranny to get engine in. ed
Thanks Ed. That was really helpful.
drop it as a unit
I never took out a 911 motor before until a couple of months ago. I was at work so time is never on you side. I followed the pelican engine drop tech article and no crap in my lunch hour with help from a coworker and no lift (except jacks) we had the motor and tranny sitting out of the car. Plus trying to line up the clutch fork through the inspection hole that is located on top of the trans seems tough trying to do it in the car.
I actually thought when it was done that I must have forgot something because it went to easily. |
Thanks Sleepy for rubbing it in.
Hi Rick -
I'm not an expert by any means. I've dropped my engine a few times solo - always WITH the trans. attached. It's not that much more work - CVs and 2 bolts - piece of cake. I think the time spent pulling the tranny will more than offset the difficulties you're having now. JMHO. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I have had my engine in and out so many times. Make sure your shifting coupler is out of the way, slide the output shaft of the tranny in first, then lift the motor in straight up, that was the best way of doing it......I wonder if haveijng a short bodied car would make a diff. Never thought about that before....
anyone else had issues with transmission mounting interfering with engine install? pipe up if you have "sport" transmission mounts too - someone here thought they could be contributing to the problem. |
