Carrera script and stone guard
I was wondering if anyone had a picture of a 3.2 with the side Carrera script and the rear fender stone guards installed. Having looked through dozens of threads and pics I saw a lot of beautiful cars, but none with this together.
I have a white 1984 Carrera with the black stone guards and want to add the script, but from my reading getting the stone guards off is a PITA and might damage the (all original) paint too. But I prefer the "clean" look of script with no guards. Any opinions/pics?
Old 02-23-2009, 02:12 PM
Post #10
WTB black Carrera side script
O2 In Sully We Believe
Old 02-23-2009, 02:52 PM
Cooper911SC's Avatar
In Buckterrier's link it looks like that owner moved the stripes forward so the lettering avoided the guard.
On our 993 (Clear guards) I put the stripes right over the guards.
You have some options: 1 Move the stripes forward. 2 Remove your guards and run stripes. 3 Remove your guards and install clear ones and run stripes over them. (I sell/install clear bra material).
Removing your original black guards will be a little bit of a PITA but shouldn't damage the paint. It will be helpful to park the car in the sun and let the material get warmed up, next start peeling it off. if you are lucky you will get a good run and it will come off in one pull...not likely...more likely you will get little 1" or 2" strips. The adhesive will stay behind. You will need a mild adhesive remover like
3M. Or you can use a citrus based bug and tar remover. This will take quite a bit of work and patients.
The other alternative is to use a drill driven low speed rubber graphics eraser.
I like the stripes on our 993. The 2 tone is a little different.
Good luck with your project.
Cooper
PS the black guards are still available from Porsche should you want to put the car back to stock apperance.
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 02-23-2009, 03:54 PM
Thanks guys. Somehow the first thread/pic slipped by me. I'd have to look at the graphics from Mikez when they get here, but if that's what it looks like in person, I may take the plunge and take the the guards off - maybe a job for my local custom shop in that case.
Old 02-23-2009, 04:51 PM
cfries's Avatar
Mine is not a 3.2 but it is white. Hope this helps. I was thinking of removing the stone guards and just having the script. Waiting for summer to peel it off
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 02-24-2009, 01:55 PM
cfries's Avatar
damn, picture too small. PM me if you want the 2Mb version
61 VW Karmann Ghia
63 European Bug
75 911 Targa
Old 02-24-2009, 02:00 PM
Super_Dave_D's Avatar
I just removed my side black stone guards in preparation for Carrera side scripts. I used a heat gun on the stone guards and they came off like butter. No problems at all!!!
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 03-09-2009, 12:22 PM
Where did you guys purchase the rocker stripes?
I am am also looking for hood stripes.
TIA.
Old 08-18-2009, 05:42 PM
skinnerd's Avatar
I agree....
I'd lose the black stone guards and replace them with clear ones.
Then the Carrera stripes will look fine.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 08-18-2009, 06:11 PM
Hi Luvair, Try Pelican Mike Z. He has the graphics.
PCA/OCR since 1997
Old 08-18-2009, 08:55 PM
scotricker's Avatar
wife's hair dryer to remove stone guards.. worked fine, peeled right off.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 08-19-2009, 08:01 AM
When you pulled off the stone gurds either with hair dryer or heat gun, was there a lot of residue leftover? If yes what did you use to get the residue off?
Was thinking of doing the script as well...
Old 08-19-2009, 12:14 PM
I have recently had several 993 owners come to me for stone guard replacement. Sometimes the guards come right off in one or two pieces...sometimes they shred into very tiny 1/8" pieces...
If this is the case your best tool is a rubber graphics eraser disc chucked up into a drill. The Wurth ones work the best IMO and are about $25 each.
The last 2 993's I did used one entire disc for the removal and about an hour per side! If the car is a driver the right side one tends to get extra baked on because of the oil tank location.
For any left over adhesive you can use a product like 3M General Adhesive Remover or SEM Solve...I even use lacquer thinner if it is really gooie! Just be careful not to rub too long in any one spot!
I typically follow this up by buffing the quarter panel before installing the new guard.
My $.02
Cooper
PCA/OCR since 1997
Old 08-19-2009, 06:29 PM
Another tid bit here...
The factory book called out Carrera script placement of 50mm above the rocker with the "C" starting 10mm back from the drivers leading door edge and the"a" starting 10mm back from the passengers leading door edge.
When we put the script on our 993 this placement looked too high because the 993's don't have the older style rocker deco strips. Lowering the script to 40mm above the rocker solved the issue.
Cooper
PCA/OCR since 1997
Old 08-19-2009, 06:34 PM
Cooper,
Sounds good, I'll give your technique a try!
Old 08-20-2009, 01:53 PM
I too had the same doubt can anyone give me some technique?
Thanks.........
http://www.e-datapro.net/
Old 02-10-2010, 05:57 PM
Hi John what are you concerned about? Stone guard replacement or the Carrera graphics?
Glad to help/elaborate as needed.
Cooper
Old 02-10-2010, 08:01 PM
porsher
aston@ultrasw.c's Avatar
here's my 86 in the configuration you describe - yeaaaah!
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-11-2010, 10:10 AM
