Old 60's Porsche Tech
captainlewis's Avatar
Question Attn: 3.2 engine tuning gurus help???? Update see last post!!
I hope I am not wearing out my welcome with so many posts, but some have you have helped me fix almost every problem on my 1985 Carerra.
174,000 miles on Engine
current status:
Idles great
good power
great compression
50lbs of lio pressure 3200 rpm
200 degree oil temp never to hot
1 qt of oil burn every 1400 miles
work in the last 2 weeks
replace spark plugs with bosch 7s had 5s (ht range)
replace cap & rotor
replace fuel filter
techron fuel treatment
fuel pressure & regulator tests to spec
02 sensor test to spec
valve adjustment
replace head temp sensor 2 wire update
clean K & N air filter
new DME relay
full throttle switch tests to specs
oil & filter change
test for vacuum leaks
california smog test (technician stated running very clean
no djustments necessary
Not done
spark plug wires, I tested resistanceare pliable look oem
no spraks in the dark
no out of car injector service
LOW FUEL MILEAGE 22 MPG AT 72 MPH WITH CRUISE ON FLAT RUNS[
EVERYONE SAY TO LOW A MILEAGE FOR CAR AND MY 1984 TARGA GOT 27
OPEN TO SUGGESTIONS QUESTIONS ETC. THANK YOU jl
Old 02-24-2009, 05:13 PM
It isn't always the engine. Alignment can make a huge difference. If you have too much toe in or out, your mileage goes out the window.
I have two cars that have the driver information display for instantaneous gas mileage, a 99 Dodge Intrepid and 99 Grand Caravan. I've been experimenting with the toe on both cars and, without a doubt, the slightest misadjustment does make a huge difference.
Old 02-24-2009, 06:09 PM
kodioneill's Avatar
how are you checking your mpg ?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-25-2009, 06:30 AM
200 mile runs full to full gas station near freeway no traffic flat run. JL
Old 02-25-2009, 07:28 AM
kodioneill's Avatar
what type tires and sizes are you running? is the o2 sensor plugged in? and how old is it?
1982 chiffon 911sc
Old 02-25-2009, 07:36 AM
Long shot but check for brake pad drag. Get an inferred temp gage and hit each of your wheel centers with it after a cruse (or put your hand on each). The stock rubber lines can swell and retain pressure in the caliper or a piston may just be hanging up. You might start by jacking the car up and spinning the wheels
Some times the O2 can get lazy. They still output correct voltage but they do not react as fast as they should.
There is a Ca smog jumper under the drivers seat. It is a brown wire. Pluged in is supposed to make the car run leaner. Do not know if this will effect things.
Changes in wheels from light weight 15 Fuchs to 17" cast rims can effect MPG some to.
Old 02-25-2009, 07:44 AM
O2 sensor plugged in sensor is new, stock size tires 205 55 16 front rear 225 50 16, thank you jl
Old 02-25-2009, 07:55 AM
kodioneill's Avatar
my 82 has 130,00 and the rear brake lines were plugged. so as the previous poster said check for brake hang up.
just to note my 85 carrera has 15 inch rims.
1982 chiffon 911sc
Old 02-25-2009, 08:38 AM
Hi
Targa Me's Avatar
It sounds like you've done all the right things to your engine. Along with the alignment make sure you're tires are properly inflated.
FYI: Here's how I check my mileage.
Fill up tank until the nose clicks off on its own.
Set the odometer to Zero.
Don't fill up again until you are near the empty.
Fill up tank and note the gallons.
Note the miles on the odometer.
Divide the miles by the gallons filled.
Ex: 430 miles divided by 16 gallons = 26.875 mpg.
Old 02-25-2009, 12:04 PM
with today's fuel having 10% ethanol by volume and that alone means about 10% less mileage per gallon due to the energy content in ethanol is less than an equivalent of gasoline (octane), 22 mpg instead of 27mpg is not too low. Also try the same test at 60 mph runs and see what the mileage is. If it goes up then it is aerodynamic drag that is lowering your mileage.
Old 02-25-2009, 12:14 PM
burgermeister's Avatar
Sounds normal to me. That's about the mileage I get.
EPA rates them at 16/23 ( www.fueleconomy.gov ) using the current rating scheme. I have never exceeded the EPA highway mileage on any vehicle, at least not since driving through Ohio during their peak revenue enhancement years (aka late 80's) going a steady 55.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-25-2009, 02:21 PM
Burgermeister, You are probably right, I am beginning to think I am chasing the mileage ghost. When I had my 84 carrera gas was real gas. I am going to send my dme control Unit to Steve Wong for a bench test and have one of his chips installed as I heard that this mod make them run a little crisper I might gain some mileage then. I am anal by nature, hence porsche technical freak, I really dont care about the expense, I would love to have enough time on my hands to go broke from the expense of driving this car. Thank you for your input. JL
Old 02-25-2009, 04:09 PM
m110's Avatar
Captain lewis
I get similar mileage, maybe a little more if I was to do a flat, constant speed run, but rarely past 26mpg.
The engine's lowest full load specific consumption is 187 g/hp/hour at 2600 rpm which is about where you're at 76mph in 5th.
I'll bet if you dyno'd your engine you'd find it was a little off the mark after all these years. I also noticed a mph increase running without a cat which I surmise is from a slightly clogged but functioning cat. Ride height, weight, tire rolling resistance, altitude, temperature, driving style and how long it has been since you passed a snarky Subaru or M3 all have a bearing as well.
1988 Carrera Coupe
Old 02-25-2009, 04:32 PM
2600 RPM at 76MPH in 5th? Surely that's not stock gearing. 3100-ish is more like it I think.
Old 02-25-2009, 04:48 PM
m110's Avatar
Yes, it was a big "about". My apologies.
My G50.01 gear chart with 215/60-15 tires has 2600rpm at about 62mph and 76mph at 3200rpm. Still both in the relatively efficient range for cruising although I think there still is a difference in consumption.
1988 Carrera Coupe
Old 02-25-2009, 05:09 PM
Update need more help???
Had Steve Wong bench test DME controll and install SW stock chip. Mileage before 21 hwy mileage after 21 hwy same test long run over same road cruise on 72 mph. I love the chip and the new found performance but I ams still hunting for a solution no so much to get higher mileage but to cure my curiosity of what I have missed, I have checked for brakes hanging up, any info appreciated, thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 03-04-2009, 08:10 AM
Mark Dia Gruppe's Avatar
You mentioned you got 200 miles out of 16 gallons, but you said you're getting 21mpg. Wouldn't that be 12.5 mpg? 200 miles divided by 16 = 12.5 mpg. If you're getting that kind of gas mileage, then yes, something is definitely wrong.
Mark Hutchinson
1984 Guards red Carrera M491 Factory Turbo-look
Old 03-04-2009, 03:49 PM
You might also consider the fact that the 911 gas tank has an inverted bowl inside the spare that is either filled with air or gasoline or some combination of both that makes it almost impossible to make an accurate reading on your re-fill.
As long as we're getting totally anal about this, we might as well take everything into consideration and not assume anything.
Of course, the assumption is that the amount of air trapped inside the bubble would remain fairly constant, but I wouldn't bet my life on it, as even the slightest discrepancy would influence your calculations dramatically.
Cheers,
Joe
74 911 w/86 3.2 conversion
Old 03-05-2009, 10:55 AM
thanks for the input. I fill the car at the exact same station the exact same pump parked at exactly the same spot when I refill, as an update retested intake manifolds for vacuum leaks disconnected the o2 sensor and idle speed controll valve, and it surged at idle will do the intake manifold gaskets and go from there, JL
Old 03-05-2009, 11:15 AM
Originally Posted by captainlewis View Post
... but I ams still hunting for a solution no so much to get higher mileage but to cure my curiosity of what I have missed, I have checked for brakes hanging up, any info appreciated, thanks JL
Tire pressure. I like to keep mine at 40 psi on all corners.
Different tires have different rolling resistance. Do you know if the tires you have are rated for rolling resistance?
Alignment still needs to be addressed.
Do you know what your no load AFR is at 3200 rpm?
Old 03-05-2009, 11:22 AM
