Can an 83 Valence be replaced with an 85? Without modifications.
Want to replace my 83sc valence with an 85 valence. Will this work and will this bolt right on? Thanks
Old 03-02-2009, 08:58 AM
Super_Dave_D's Avatar
Yes as long as you plan on replacing the fog lights as well.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 03-02-2009, 09:04 AM
Thanks, I just need 85 fog lights, right? And they should just replace my old ones.
Old 03-02-2009, 09:11 AM
You may need to change the washer tank to the newer version that has a recessed area for the fog lights. I put a newer ('84 I think) valence on my '81SC and had to replace the washer tank. Found a used one and everything fit perfectly.
mike
Old 03-02-2009, 10:14 AM
the SC washer tank does interfere with the left carrera fog light body.
206 637 4071
Old 03-02-2009, 10:25 AM
frankc's Avatar
And I believe the washer pump is also attached directly to the 84+ style washer tank, rather than being mounted in the trunk.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 03-02-2009, 07:20 PM
So now it sounds like I need both the washer pump and washer tank..........anything else?
Old 03-02-2009, 07:37 PM
you might have to bend the horn brackets around slightly to clear the back of the passenger side fog lamp
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 03-02-2009, 10:41 PM
