Can an 83 Valence be replaced with an 85? Without modifications.
Want to replace my 83sc valence with an 85 valence. Will this work and will this bolt right on? Thanks
Yes as long as you plan on replacing the fog lights as well.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
Thanks, I just need 85 fog lights, right? And they should just replace my old ones.
You may need to change the washer tank to the newer version that has a recessed area for the fog lights. I put a newer ('84 I think) valence on my '81SC and had to replace the washer tank. Found a used one and everything fit perfectly.
mike |
the SC washer tank does interfere with the left carrera fog light body.
And I believe the washer pump is also attached directly to the 84+ style washer tank, rather than being mounted in the trunk.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
So now it sounds like I need both the washer pump and washer tank..........anything else?
you might have to bend the horn brackets around slightly to clear the back of the passenger side fog lamp
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
