Thx Gabe, alot of kudos flying around today, so back at ya, you and ur DZug boys
are coming up with really cool retro 70's 934-935 stuff, need to order that 917 era gas pedal soon, can't wait to stomp on it!!!! "porsches are like dogs, always findin the tail and sniffin each others ass" http://forums.pelicanparts.com/uploa...1312304551.jpg |
Any more progress man? I hope so. I got a little bit more done on mine too. It's all posted on funfgruppen. Getting ready for the cage next month and the beginning on the motor tear down!!!
Chris |
Hi Chris, just waiting on the fabwork to be finished on the intercooler and tank and then will bring back home to put all the fuel and oil lines, pumps as well as wiring, instruments, etc.... into car... feels like winters not far off here anway..
Will defintely check out your progress over on funf...... L8TR................................ http://forums.pelicanparts.com/uploa...1315925144.jpg |
I wish you started with an uglier car. I'd be sad if this turned out like crap, but it didn't! Niiiiiiccccceeeee!!!!!!!
Starting to make a little progress again as winter is approaching. The water intercooler and the water tank are in. Water pump still needs to be mounted up.
http://forums.pelicanparts.com/uploa...1320202685.jpg Alot of fabwork to still be done as well as welding on the lines from the intake to the intercooler and out to the turbo and so forth...... maybe this kit will do it ....... http://forums.pelicanparts.com/uploa...1320202895.jpg With all the fluid lines yet to run decided to start with the fuel stuff first. Pump is mounted , going to work my way laying out the lines from the rear. http://forums.pelicanparts.com/uploa...1320203506.jpg Need to drill for some bulkhead fittings. Running the fuel lines just to the side of the center tunnel passengers side. Will post some more when I get finished with fuel lines and get the oil lines layed out. http://forums.pelicanparts.com/uploa...1320203800.jpg |
awesome build. These builds keep me motivated on my race car project
Michael |
I totally forgot you cut out the rear bulkhead area. I'm thinking about the same for mine. I'm just a few steps (read a lot of money behind lol) behind you. Trying to see the pros and cons of it.
Awesome as always brother! Chris |
Hey Chris, I would only cut out the rear seat area if you are building a dedicated track car. The pro's are easier access to starter, trannie, engine, etc. Not much weight savings if any, my aluminum cover is not much less in weight than what I cut out. And unless you are putting in a cage it probably lessens a small amount the structural integrity in that area not to mention more noise. So if its really more of a street car I'd leave that area alone. L8TR, Tad
Tad, thanks man... Im thinking about it still. I like the idea of the easy access to the tranny, but the down side would definitely be if something blew apart. GrantG has a nice setup, here is a photo I found of it.. Im waiting on him to email me some more photos and hear what he has to say about it...
http://forums.pelicanparts.com/uploa...1320287384.jpg http://forums.pelicanparts.com/uploa...1320287403.jpg |
subscribed
This is one of those feel good days where you think your getting somewhere on that never ending project. With a five year anniversary on this one coming up in february I'm pushing harder to have this rig runnin by spring. Did some fuel line and oil line routing and so forth. -8an for fuel and -20 supply and -16 return for oil lines, made holes for bulkhead fittings, reworked the original fuel return and feed to the accumalator with steel -8an fittings to hook up fuel lines.
http://forums.pelicanparts.com/uploa...1321843239.jpg http://forums.pelicanparts.com/uploa...1321843384.jpg http://forums.pelicanparts.com/uploa...1321843448.jpg Going to run three front oil coolers since I'm at altitude, can always run with blockoffs in cool weather if necessary. Welded up a frame for the center oil cooler and made a cover screen semi protective cover for the center oil cooler mainly because it so close to the ground . Need to fab up brackets for the side oil coolers next. Also mounted up the scavenge pump for the turbo since doing away with the cam driven pump. http://forums.pelicanparts.com/uploa...1321844466.jpg http://forums.pelicanparts.com/uploa...1321844585.jpg Using a fender oil cooler for my radiator for the water cooling to the intercooler on the passenger side and the tank being directly behind it makes for a short feed on lines. Will draw air from the right side naca duct into the radiator and have a fan I may mount to draw additional air if necessary. http://forums.pelicanparts.com/uploa...1321845281.jpg Also mounted the breather tank, oil filter and the thermostat. Will finish hooking those up once I get the outside oil coolers mounted. http://forums.pelicanparts.com/uploa...1321845890.jpg Ok, going over all this made me thirsty...........beer break..........L8TR..... |
Good lord Tad. You are killing it over there. Man, progress feels great doesn't it?
I have a quick question I hope you don't mind answering?
I am about to stick some bolt on arches to my Boxster racing car and not sure what type of fasteners to use - do you have some details on the ones you have used for your arches? Been following with interest from the start BTW, great attention to detail... |
Hi Paul, I used small 3mm hex head bolts, couple washers and locknut. Most people use rivets which is probably better for racing in that you can change out a flare piece much quicker. I was having some cracking issues with my flares so went with the bolts so I could vary the tightness and relieve stressed areas around the flares. Hope this helps some, good luck and be patient working with that fiberglass, it can become a mess real quick. Cheers, Tad
Cool, thank you... I will probably do the same as you. I want to be able to easily remove them when I need better access.
two thumbs up!!!!
Figured out how I wanted to mount the two outside oil coolers. Mounting to three points on side of frame. http://forums.pelicanparts.com/uploa...1323395205.jpg
Everything pretty tight to line up with the outter air inlets and still be able to connect fittings and hoses. With three oil coolers in series its going to be a challenge to get everything to fit. http://forums.pelicanparts.com/uploa...1323395818.jpg Oil coolers are covered to protect the fins with all the in and out for fitment. One side welded up and painted and ready for hoses. Will get the other side done and get going on the lines up front next... http://forums.pelicanparts.com/uploa...1323396249.jpg http://forums.pelicanparts.com/uploa...1323396408.jpg Will line up with valence well .... bottom bar will be good to help support the air duct for the brake cooling http://forums.pelicanparts.com/uploa...1323396544.jpg |
This build and Zuluracerx's are the bar by which all others should be measured by. Well, I could list a couple more (TRE involved), but don't want to come out looking too envious ;):D:rolleyes:
Once I am done with this new condo, I am hoping to fulfill a long time dream (fat bodied old school 911). Just in time for my 40th birthday too http://forums.pelicanparts.com/support/smileys/ura.gif |
any news?
Thanks Tom for reminding me to update. Finished up all the oil and fuel lines and got everything routed and hooked up.
http://forums.pelicanparts.com/uploa...1330298920.jpg Used 90 deg bulkhead on sides to keep lines as close to inside as possible http://forums.pelicanparts.com/uploa...1330299125.jpg Line going to outside cooler and routes inside bumper down to center cooler, then routes out of the right side cooler and back to thermostat and to tank. http://forums.pelicanparts.com/uploa...1330299259.jpg Lines run for the turbo scavenge pump and drip tank. http://forums.pelicanparts.com/uploa...1330299564.jpg http://forums.pelicanparts.com/uploa...1330299623.jpg Mounted the water pump for the intercooler http://forums.pelicanparts.com/uploa...1330299755.jpg Mocking up the radiator mounts and will make supports to hold it next and run the water lines. Need to modify the cover so naca ducts in the quarter windows can flow air the radiator. http://forums.pelicanparts.com/uploa...1330300290.jpg Mounted cutoff switch. Should be able to start car wiring soon. http://forums.pelicanparts.com/uploa...1330300845.jpg |
| All times are GMT -8. The time now is 09:35 PM. |
