Turn signal/ hazzard flasher issue
Maybe someone has had this issue. The other day I fired up my car [78 SC]and took it for a spin and noticed that the turn signals were not operating. No big deal, I figured the turn signal relay had finally gone south...guess they only last 30 yrs. So today before I placed an order for a new one I went out to the car and tested it again. I found that with the ignition switch in the run position the turn signals and hazards work fine. If I start the engine the hazards and the turn signals hang and do not work or flash very slowly. Any thoughts on this?
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
possible turn signal switch. lot of posts on this. they seem to be failing a lot these days.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
We drive Porsches so we don't need to use turn signals
Bump
Ron,
1. Do you have the Bentley service manual for your car? 2. The power to most relays in the car comes from the ignition switch. The switch has as many as three positions it can be in to supply power. ACC, Run, Start. With the problem you describe, it sounds like it could be a bad feed from the ignition switch. Gordon |
My golden rule
When I mess about with electrics I always clean all electrical connections involved. I am amazed at how many times this cures the problem.
Worst case, you use a little time and have nice clean connections for the new unit. JR |
Thread Tools | |
Rate This Thread | |
